The skill of the Victorian woodcut engraver
Home Forums The Tea Room The skill of the Victorian woodcut engraver
  • #813955
    vic newey
      @vicnewey60017
      I thought this might be of interest to those of you with vintage machines who no doubt have original, or scans of, the catalogues they issued back in late Victorian times.
      The photo shows the amazing skill of the Victorian woodblock engraver compared to the photo he copied. Early printing of catalogs could not economically transfer photographs so still relied on the 100’s of years old skill of woodcut engraving which had to be in reverse for printing.
      double
      Pete
        @pete41194
        I knew a tiny amount about that woodblock engraving and printing method Vic, but not that it could do detail like your example. Amazing and thanks for posting it.
        #813992
        John Haine
          @johnhaine32865
          Difference between woodcut and wood engraving. Engraving is an intaglio process where you cut a line in an end grain block, ink the block then wipe off the ink except where it has filled the engraved line.  So where the line is comes out black.  Woodcut is I think where you cut away where you want white and the ink sticks elsewhere. That is a negative process.  I’m married to a printmaker…
          #814037
            By that time they probably used an optical projection method to assist. Are you able to see on the original whether it is in fact a manual operation rather than early lithography?
            #814053
            vic newey
              @vicnewey60017
              It’s dated to 1888 and I presumed it was cut in wood but I think your right that the method used was probably lithography but the plate still had to be engraved with great skill. The engraver was Franz van Himbergen who went on to engrave many of the lathes and sewing machine catalogues for the Pittler company. Here is a catalogue page featuring that early latheMaschinenfabrik-Invention-0003
              #814063
                I suspect Vic’s example is Photogravure because it’s so good.  I maybe wrong because woodcuts were widely used and could be high quality. In technical works though, the lines tend to be more obvious.  Very effective – this example is a woodcut from  the 1874 ‘Catechism of the Locomotive‘ : plenty of work in it.
                catechism
                Whilst this (from wikipedia) is photogravure (1883):
                Photogravure puts a gelatine photographic image on a copper plate which is then etched with Ferric Chloride.
                Best admired from a distance – though Victorians were hardworking and innovative, they were paid pennies for 80+ hour weeks and died young.
                On thing that hasn’t changed – advertising bling, with posed products!  That well-groomed young man in a suit is unlikely to have been a turner.
