12 volt pinger – Ding a Ling
Home › Forums › Electronics in the Workshop › 12 volt pinger – Ding a Ling
  • #733531
    Speedy Builder5
      @speedybuilder5
      I have an older mini and even older ears!  Does anyone know of a sound device that I could connect to the indicator circuit that would give a pleasing sound warning that the turn indicator has been selected. There are plenty of buzzers, but I was looking for something pleasant sounding. I am sure there are things like Arduino or Raspberry Pie, but surely that is overkill.
      Bob
      #733532
        It appears that you are not alone in wishing for that, Bob
        … useful discussion here:
        https://community.element14.com/members-area/f/forum/39027/miniature-pleasent-sounding-buzzer
        John Hinkley
          @johnhinkley26699
          Bob,
          It’s a legal requirement in the UK to have either an audible or visible indication in the driver’s position to show that an attached trailer or caravan’s indicators are functioning.  I imagine that the same is true of France.  So that would be my first port of call – a caravan dealer or tow-bar fitter.  A buzzer suitable for a motorcycle would be most unpleasant to listen to and fairly intrusive, if cheap! A chime is what you’re after, I guess.  A bit of a risk just buying one off the Internet; better to get a demonstration, in my opinion.
          Pagesjeunes.fr for your area may give some leads, but in my experience very few small businesses/garages etc in France have websites to view.  Mind you, that was ten years ago.
          Harry Wilkes
            @harrywilkes58467
            anything like the one in my car is enough to drive anyone round the bend !
            H
            #733712
            Anonymous
              I have never been able to hear the turn signals in my (now 14 year old) Altima. Looking on the internet it seems that many others have the same complaint Both the dealer and Nissan say they can’t make it louder – don’t know why, I’m sure it’s done in software (not a mechanical buzzer). Nor has it been improved over the years apparently.
              Funnily enough, improvement has come with age-related hearing loss. Now that I wear a hearing-aid, I have a phone app that lets me adjust both the frequency profile and volume of the hearing aid and I derived and saved a profile that works very nicely with the turn-signals and can be turned on while driving.
              #733720
              Robert Atkinson 2
                @robertatkinson2
                Sounding nice is subjective.
                You could try a NE555 timer based chime. Search ebay etc for Door Bell DIY Kit NE555. Lots of sellers for a few pounds so not a big risk.
                Normally “triggered” by a push button but you could try just powering it with the indicator light switched voltage (button pressed or not will give diffeent response) or connect the supply to switched ignition and the indicator switched voltage to the “diode” side of the push button switch.This is one random supplier that give the circuit on their website. Never used them, no connection to them.
                https://www.icstation.com/electronic-doorbell-ne555-electronic-production-transformer-sound-circuit-processing-board-p-13092.html
                Robert.
                #733722
                bernard towers
                  @bernardtowers37738
                  Caravan one might be the way to go they have been around a long while so might have got the sound level right.
                  #733756
                  Speedy Builder5
                    @speedybuilder5
                    Thanks for the replies, but not quite there yet (Am I too picky ?).
                    #733758
                      Maybe, maybe not … but I think you’re probably going to have to make your own choice now, according to taste and complexity.
                      Edit: __ You might find it helpful to browse through these pages to find some sounds for a short-list:
                      https://www.soundsnap.com/tags/warning
                      #733790
                        Silly suggestion
                        Buy a small 8 ohm loudspeaker, insert a current limiting  resistor, (560 ohms  or more to limit the current to about 30 mA?) in series, and connect in parallel with the indicator circuit, (Across the wires feeding the near and off side lamps). That should make a loud enough noise to be heard!
                        If the loudspeaker impedance is not 8 ohms, adjust the resistor value to limit bthe current to 30 mA or less.
                        #733792
                        Tim Stevens
                          @timstevens64731
                          Anyone following Howard’s advice might be frustrated, as the connection needs to be from something powered to earth. Connecting the two ‘output’ leads (going to the flashers each side) might work, or it might stop the system from working, or you might get both flashers on whichever way you click the control. And a loudspeaker will only produce a click for ON and another (quieter) for OFF, so it simply might not be heard at all in traffic.
                          The connection needs to be from some sort of oscillator (buzzer, etc) or musical device (not just a transformer) and you connect it from the output from the flasher unit (which goes to the ‘common’ connection within the flasher control) and to earth. This ensures that the new musical device gets current when either the L, or the R, flashers are in use.
                          Yes, its a bit complicated, but not as much as heart surgery (and that is done without stopping or blowing up the engine.)
                          Cheers, Tim
                          #733854
                          Paul Lousick
                            @paullousick59116
                            Have a look on ebay for DC12V wired doorbell with music. Some have a selection for different music.
                            #733867
                            Nimble
                              @nimble
                              Could one take Robert Atkinson’s Ding Dong devices and change the circuit by short circuiting S1, connect J1 -1 to current indicator, J1 2 to earth
                              and connect the LS1 leads to perhaps front drivers side radio speaker thus getting a pleasant sounding sound without having to find space for another speaker?
                              These boards are also obtainable off Ali Baba sites.
                                The usual technique, for filament type lamps, is for the warning lamp to be connected between the feeds for the lamp on each side. The 21 W lamps provide a sufficiently low resistance path to earth for the 2.5W warning lamp.
                                This is the way in which Lucas arranged their indicator switches.  It has the advantage that if one of the “earth path” lamps fails, the warning lamp is less likely to illuminate, warning of a failure.
                                On later LED type lamps, as Tim says, there needs to be a direct path to earth, so the feed from each side might well need a diode to prevent energising both sides at the same time.
                                I am certain that applying 12 V to a loudspeaker will provide a loud enough “click” to be heard.  Try applying a 1.5V cell across the speaker!
                                The current limiting resistor is necessary to protect the speaker,(And the diodes).  I doubt if a 8 Ohm speaker coil would withstand a current in excess of 1.5 Amps for long!
                                #733899
                                Circlip
                                  @circlip
                                  And there are times when the warning bleeper can be REALLY annoying. Had problems with my Sandy Ro driving home from a shopping trip. Beeper kept coming on and stopping intermittently. Did a quick visual of all the ‘normal’ trigger generation sources, Lights, handbrake, doors etc.. Eventually found the source, I had risked the safety of my shopping by NOT fastening its seat belt on the passenger seat. Not heavy enough to trigger the unit when stationary, but various driving manoeuvres did.
                                  Regards  Ian.
                                  #733903
                                    Like Circlip, I found that very little weight on an “empty” seat made the system think that the seat was occupied; calling for the seat belt to be fastened.
                                    Now the bag either goes on the floor, or the belt is fastened, just to make the system happy.
