bespoke castings
bespoke castings
  • #719159
    JACK SIDEBOTHAM
      @jacksidebotham67303
      can anyone recommend a foundry to take on a one off casting for me??,l need to get the Dore Westbury motor mount parts cast,l dont have the facility to do it myself or the equipment,so l need to farm the job out,any advice is welcome,thanks,jack.
      #719160
        https://purbrightcastings.com/
        https://www.graydoncastings.co.uk/
        Both have cast from my wood, metal and plastic patterns and also 3D printed ones by others from my CAD files. Mostly by Graydon and I have been machining some of theirs over the last couple of weeks. Graydon will cast from patterns posted to them and send the castings so location is not such an issue.
        Not used these but another option to try if that is your part of the world  https://eastcoastcasting.biz/services/
        #719162
        peak4
          @peak4
          I guess it depends where you live.
          Leander castings are just north of Buxton Derbyshire.
          I’ve never used them, but did go on a foundry tour a few years ago
          ill
          #719164
          David George 1
            @davidgeorge1
            I have had a few castings made and am in he process of having a handwheel casting made. I use Sutton castings local to me  https://www.suttoncastings.co.uk/     not far from Mansfield and Greenbank Patterns Kirkby in Ashfield to make the patterns. the most expensive part is the pattern which if you could make your own reduces the price dramatically.
            David
            M type fixed steady20220204_121803
            #719166
            duncan webster 1
              @duncanwebster1
              JT&E castings in Wigan Lancashire
              #719191
                Looks like a superb finish on those patterns. Plastic? 3D print? I don’t see any draft angle.
                #719194
                JACK SIDEBOTHAM
                  forgot to say that l am located in chepstow south wales
                  #719208
                    Photo of the casting seems to show draft better than the one of the patterns. With most foundrys now using some form of airset sand you don’t need much angle I/ve been using 2deg for the patterns I’ve been doing the last couple of years
                    draft
                    2deg draft on these patterns
                    401100228_1297481530949785_5331616546400150489_n
                    Casting came out OK
                    cast2
                    #719258
                    David George 1
                      @davidgeorge1
                      The patterns for the fixed steady were CNC cut by Greenbank patterns from a drawing from the files section which looked like an original drawing. They were cut in a resin plastic block.
                      David
                      #719260
                      Fulmen
                        @fulmen
                        @Jason/David: Could you give a rough price for those parts (assuming you supply the patterns)?
                        #719288
                        Nigel Graham 2
                          @nigelgraham2
                          Bridport Foundry is another bet: they make the Stuart engine castings.
                          #719426
                          David George 1
                            @davidgeorge1
                            #719497
                            Fulmen
                              @fulmen
                              Thank you David.
