As usual it is horses for courses. There are as many opinions on parting as there are model engineers but here are some thoughts:-
1. You are parting off brass. It is best to use a back rake of about 7 deg. for steel but zero for brass. Your pictured tool has back rake.
2. Yes an angled tip can help decide which side the pip is left BUT it introduces a sideways force. Also the swarf is wider than the slot and can jam. Make sure the saddle and topslide are locked and that there is minimum overhang on the tool to make everything as rigid as possible.
3. G H Thomas always recommended grinding a slight "v" (convex) on the front face of the tool and a slight concave "v" on the top so that the swarf tends to curl in and become narrower than the cut. I have used that method for years. I still get a small pip on the work but not like yours.
Just my two euro cent's worth.
Russell.
