Plans for Centre Finder Wobbler tool
Home › Forums › Beginners questions › Plans for Centre Finder Wobbler tool
  • #125619
    Jerry Cashman
      @jerrycashman49324
      HI guys, I've got to use a 4 jaw chuck for the first time soon so have been reading up on how to easily centre work… I found a reference to a simple looking tool called a Centre Finder Wobbler which has a mount you place in the tool holder, than a longish indicator bar which has a short end and long end with a ball mount in the middle – you carefully put the short end in the centre pop of the workpiece then as you rotate the chuck the long end wobbles about to indicate which way you need to tighten the 4 jaw – sounds much simpler than fiddling around with DTI's for irregular components….
      Can anyone ether tell me with I can buy something like this or share 'how to' plans so I can have a go at making one myself please?
      cheers. Jerry
      Canberra – Australia
      #6804
      Jerry Cashman
        @jerrycashman49324
        #125620
        Springbok
          @springbok
          Hi Jerry
          Could you tell us what the part is you wish to centre find as there are many ways of doing this. A piccy of item would be helpful
          Bob
          #125621
          Jerry Cashman
            @jerrycashman49324
            Hi Bob, it's a very simple part – I'm going to be building an Elmers #25 Wobbler and the cylinder is bored into a rectangular block, with the cylinder bore off-set a little from centre of the rectangular end – so I plan to mark up and pop the centre of the hole, then mount the block in the 4 jaw (a bit offset) and drill/bore.
            cheers. Jerry
            #125623
            Thor 🇳🇴
              @thor
              Hi Jerry,
              I don't know if this is what you were looking for? Here's another with plans in dxf format.
              Thor
              #125624
              Jerry Cashman
                @jerrycashman49324
                Thanks guys, the tool I'm looking for looks a bit like the following…
                I'm sure I've seen plans for one somewhere, but can't find it now that I want it
                #125626
                Clive Hartland
                  @clivehartland94829
                  Easiest way is put the block in the 4 jaw chuck with center pop towards tailstock. Bring up tailstock and place another MT center on the tailstock center and the point in the center pop. The MT center will wobble as you turn job and you can by eye bring it into center very easily, then using a DTI complete the centering accurately. No need to buy any expensive one off tooling.
                  #125627
                    I have seen plans somewhere, give me a while to dig them out.
                    But my preference is a sprung centre they located into yout punched hole and the tailstock centre, this gives a round surface that you can then put a DTI against.
                    Firefly3
                    The spring keeps the tool in place as the work moves about unlike doing it with a solid pointed bit of bar, I'll dig out a drawing later unless someone else comes up with one.
                    J
                    #125628
                    Andyf
                      @andyf
                      Jerry,
                      Like Thor, I favour the sort which is supported by a centre in the tailstock, and using an indicator on the end near the workpiece. I made one; picture here. The cannibalised dart is soft soldered to the brass tube, with a spring between it and the steel rod to hold the device in place.
                      In no way is it concentric, but as the friction between the rear end and the centre is far greater than the friction at the pointy end, it doesn't revolve and concentricity isn't an issue.
                      After taking the pic, a 1" slit was cut along the side of the tube, to take a pin into the rod, so the thing can't fall apart. All very crude, but works a treat.
                      If making one like your sketch, consider mounting the long rod in something springy, like through the hole in the end of a piece of old hacksaw blade sticking out from the toolpost. That would save the bother of a ball joint. It does strike me that the rod, which might be rather slender and prone to getting bent, must be dead straight to line up properly with the tailstock centre. But why bother lining up with a centre? Simply adjust the chuck until the far end stops waving around in little circles. Then, a bent rod wouldn't matter.
                      Andy
                      #125629
                        Here is one, if you co to construction notes you can download drawings
                        #125633
                        Eric Cox
                          @ericcox50497
                          Keep it simple. The accuracy is dependant on your abillity to place the center dot.
                          There is no point in having a fancy wobble bar and DTI if you can't place a center dot to within a thousanth of an inch.
                          #125634
                          Harold Hall 1
                            @haroldhall1
                            Here is another one to consider **LINK**
                            Harold
                            #125638
                            Andyf
                              @andyf
                              Posted by Eric Cox on 29/07/2013 08:46:22:
                              True, if you want to put the dot dead centre in (e.g.) an existing finished diameter. But if you are leaving that until afterwards, a dot which is few thou out won't matter, will it? Surely the idea of these devices is to enable the chuck to be adjusted to get the dot centred..
                              Andy
                              #125645
                                Andy say you wanted to machine an eccentric with a throw of 0.188" you would put the dot 0.188 from the center and pick that up so the placement/throw of the eccentric relies on the accuracy of the punch mark, thats when an optical punch comes in handy.
                                Or when there are more than one centre on the same item such as this its all down to the placement of the punch mark.
                                J
                                #125647
                                MICHAEL WILLIAMS
                                  @michaelwilliams41215
                                  Far better to use toolmakers buttons for any job where accuracy of setting up really matters .
                                  MikeW
                                  #125649
                                  John Coates
                                    @johncoates48577
                                    Posted by Jerry Cashman on 29/07/2013 06:28:10:
                                    Sure that has appeared in MEW Jerry. I remember the maker explaining what he used for the material to hold the "needle" in the main body. When I get home from work tonight I'll check my index and see if I can find it unless someone else posts on here first.
                                    peter ravenscroft
                                      @peterravenscroft57700
                                      try looking in one of kozo hiraoka's books (shays nad the likes
                                      ) he shows you how to make one
                                      regards
                                      peter
                                      #125659
                                      dcosta
                                        @dcosta
                                        Hello Jerry, good after noon.
                                        Using free MEW_Indexes **LINK** I found two ocurring artciles with the word wobbler in the title.
                                        Year: 1997; Issue:46; Page:43; Month: November;Author:Johnson; Title:"Centre Locating Tool version of Wobbler".
                                        Hope this helps
                                        Dias Costa
                                        #125670
                                        Danny M2Z
                                          @dannym2z
                                          G'day Jerry.
                                          Workshop Practice Series #20 'Metalwork & Machining Hints & Tips' has detailed plans & manufacturing instructions for precisely what you described.
                                          Cu Later * Danny M *
                                          #125674
                                          dcosta
                                            @dcosta
                                            Sorry, forgot hte link.
                                            Hope this helps
                                            Dias Costa
                                            Edited By dcosta on 29/07/2013 19:30:54
                                            #125713
                                            Jerry Cashman
                                              @jerrycashman49324
                                              Thansk very much everyone, really appreciate the advice and support!
                                              cheers. Jerry
                                              Jerry Cashman
                                              #125733
                                              HomeUse
                                                @homeuse
                                                Hi – Yes Kazo has details for Wiggler and other projects The Hobbyist Machine Shop – Kozo's Wliggler
                                                I have made Wiggler and other stuff which works well
                                                Mikeb
                                                #125782
                                                Jerry Cashman
                                                  @jerrycashman49324
                                                  Thats the one! thanks Mike!
                                                  cheers. Jerry
                                                  #125791
                                                  Duncan McHarg
                                                    @duncanmcharg91521
                                                    G'day Jerry,
                                                    I knew I'd seen a simple wobler plan in a 1950's issue of Model Engineer. Second one I looked in (Yay). "The Model Engineer" Feb 26th 1953 (Vol. 108 No. 2701). Looks like it would work very well.
                                                    I've put it in 'Albums' and select Latest Images. Download the file as the original is larger than what pops up on the screen.
                                                    Cheers
                                                    Duncan
                                                    #125798
                                                    Duncan McHarg
                                                      @duncanmcharg91521
                                                      I was just looking over the article and Irvine is using some Rolls-Royce aero engine ball joints, but the iliustration looks amost identical to the ball joints in the gear change linkage on our '63 Hillman Minx, so we don't have to go to the 'top of the tree' for the parts.
                                                      Cheers
                                                      Duncan
