M12 thread in stainless
Home › Forums › Beginners questions › M12 thread in stainless
  • #102047
    mark reeve
      @markreeve78288
      I am currently making an M12x 1,75 drawbar for a milling machine, but have struggled to find any clear guideance as to what should be the turning diameter, prior to using a hand die. The piece of bar I am using is 12mm diameter.
      I have measured a M12 bolt and have turned down to 11,65 dia but when I try using a die holder in the tailstock of the lathe the bar friction appears far too great and the bar simply turns in the collet. I appreciate I could use a length of Metric studding but I'm trying to gain some experience of turning and studding would be cheating. (I am using an HSS fixed die, ie no split and am using tapping lubricant) I cannot thread turn it, as my lathe has an imperial lead screw
      Any help would be much appreciated.
      Regards Pete
      #6408
      mark reeve
        @markreeve78288
        How to achieve an external M12 1,75 thread using a die
        #102050
        Kevin F
          @kevinf
          11.65mm is quiet a lot under size for cutting an external thread ,so in theory you should be able to comfortable cut the thread.
          The problem with stainless steel is it can work harden as its machined ,but in your case I'd say that your die is of poor quality , I'd buy a better quality die but one that is split so that you can adjust the die between cuts .
          #102051
          speelwerk
            @speelwerk
            Making a M12 thread with a die takes much force and it is better to use a chuck than a collet to hold the bar.
            Niko.
            #102052
            Sub Mandrel
              @submandrel
              Hi,
              If you have a screwcutting facility, I'd machine cut it if it is in stainless. The problem is that every time the bar slips the die will stop and it will work-harden the steel and its even harder to get it to cut again.
              Clive Hartland
                @clivehartland94829
                It would be better if you turned a short length of the Stainless bar to the root dia, about 5mm long and make an angled shoulder for the die to bite on.
                If the die is not cutting then both of the other reasons apply from earlier threads.
                Do you know the type of Stainless steel?
                #102056
                Terryd
                  @terryd72465
                  Use Mild steel. Stainless is not necessary and is introducing unnecessary complications. MS is not expensive. A better alternative is to use a high carbon steel. I wolu not use Stainless in this application even if it was free.
                  Best regards
                  T
                  #102060
                  Anonymous
                    If the die is not split it might actually be a dienut, which is not intended to cut a thread, but to clean up existing threads. Either way, cutting a M12 thread by hand with a die is going to take a lot of torque.
                    #102063
                    MadMike
                      @madmike
                      Mark, I know you want to gain experience but cutting a thread on a stainless bar using a die nut is NOT good experience it is a waste of effort………IMHO.
                      So if you are intent on making a drawbar from scratch make it from mild steel and get a proper split die., if you cannot screw cut the thread on your machine. Hold the bar in a chuck not a collet. The mild steel will not work harden like SS and will be more than strong enough for your needs.
                      Alternatively simply use M12 studding and turn and fit a threaded "head" to fit on the other end so that you can tighten the drawbar, and also tap it to release your collet chuck etc. You could, assuming your machine is a current one, simply buy a drawbar. This may sound like sacrilege to some on here but frankly a clever engineer finds ways to reduce work not make life lore complicated.
                      If you take the "easy option" you can spend more time gaining useful experience on using your machine to make stuff……far more worthwhile, again IMHO.
                      #102064
                      Jeff Dayman
                        @jeffdayman43397
                        Given the trouble you are having, I'd suggest threadcutting the M12 onto mild steel rod as others have, or find an M12 bolt, cut the head off, and weld the threaded end to a rod. Reason is, most commercial bolts have a machine rolled thread which is semi work hardened and the grain of the steel has been cold formed rather than ripped away as done in thread cutting. A bolt thread will give a tougher thread that will last longer in drawbar service. This is applicable to homemade clamps and machine parts too.
                        As to your trouble with the die, the die likely is not sharp enough, you could have a rough piece of gummy stainless stock, or your lead-in could be the wrong angle and maybe the small end is not small enough. For lead- in angle, 20-30 degrees per side works well, and if the end dia is about 0.5 mm smaller than the die's hole you will be sure to get it started as cleanly as possible.
                        JD
                        #102067
                        Ady1
                          @ady1
                          Just use a 35 on the spindle and a 63 on the leadscrew
                          Your diameter is fine, cut a rough thread on the lathe and finish off with the die
                          Stainless is tough stuff though, a carbide tool may be your best bet and take off as much as you can so the hss die hasn't got too much work to do
                          (I've been trying to upload some piccies but this place is a nightmare tonight)
                          Edited By Ady1 on 28/10/2012 02:37:38
                          #102070
                          Clive Hartland
                            @clivehartland94829
                            Cromwell can supply a length of High Tensile studding for a couple of Quid, easily turned and fit a Hexagon pinned through one end.
                            #102075
                            MICHAEL WILLIAMS
                              @michaelwilliams41215
                              Cutting M12 in stainless with a die will be hard going at best . Others have made the best suggestions about starting the thread with a die or using alternative materials .
                              But if I had to do such a job and imperial screwcutting was available I'd screw cut 14.5 TPI and just finish with the die .
                              14.5 tpi is easy to set up – most tables give 29 tpi so just put a 2:1 factor in somewher in gear train .
                              Michael Williams .
                              #102090
                              Ian S C
                                @iansc
                                You really need a fairly heavy die, say 2" split button die, so you can put some real weight into it, and try and take it down in one cut to get round the problem of work hardening. As others have said mild steel is quite addequate, after all it only just gets nipped up. I'v got one that I made by cutting the heads off two bolts, and welding them together, even with my welding its held together for the last twenty years. The other draw bar, a comercial one is quite hard, and is blued, not a pair of rusty bolts, but its just as good, cost two old bolts, time cutting the heads off, welding, put a washer and nut on the top end, all done. Ian S C
                                #102091
                                Ady1
                                  @ady1
                                  I'm doing the ends of a 39 inch square bar at the minit
                                  Cutting most of it on the lathe leaves the die to only finish the job off
                                  This one is finished
                                  This one needs the die to run up it
                                  It takes a bit of figuring out but saves a bucketload of hassle once you suss it out, concentricity is automatic and most of the material(and hard work) is removed on the lathe
                                  You will have additional issues using stainless which is not a user friendly material
                                  You've kind of pushed yourself too far if you haven't done it before, running before you can walk
                                  If I was you I would just buy a length of 12mm threaded rod for a tenner from B+Q
                                  #102095
                                  NJH
                                    @njh
                                    Hi Mark
                                    All the drawbar does is hold the two tapers together. You don't need great strength as you should not pull it up too tight – it's the good fit between the tapers that do the work. You will need it to extract the tapers when you need to change tooling but only a light tap should be needed unless you've really been heavy handed initially. Better still make an extractor as shown on other threads here – Sorry I don't recall which but maybe someone else will remember.
                                    I would use  studding or MS and save my stainless for another day.
                                    Norman
                                    Edited By NJH on 28/10/2012 12:09:09
                                    #102136
                                    mark reeve
                                      @markreeve78288
                                      Hi all,
                                      Thanks for the multitude of suggestions. It is amazing what you can learn in a short space of time and this makes being a member so worthwhile.
                                      In the end I opted for Jeff’s and Ian’s suggestion of cutting the head off an M12 bolt, but rather than weld it, I turned a spigot on the end and press fitted this into the original piece of 12mm stainless steel bar that I was struggling to thread. I cross-pinned these parts together.
                                      I had already machined the head cap and press fitted this onto the other end of the bar and cross-pinned it. (The result is shown in the photo)
                                      Thanks also to Ady1 for his comments re using my imperial lathe to cut metric threads. I shall be following up on that suggestion, for future projects.
                                      Appreciating that there are many other and quicker ways of making a drawbar, my main aim was to get some practice on the lathe and mill, whilst at the same time making something useful and reasonably aesthetic. The stainless steel was FOC and machined well with carbide tools, but I will avoid it in future, where threads are concerned.
                                      Kind regards
                                      Mark
                                      Drawbar
                                      #102139
                                      Ian S C
                                        @iansc
                                        Mark, that should do the job. Normally a draw bar has a thread at each end, the bottom one is screwed into the tool, the top onehas two nutsthe bottom one is for tensioning the rod, the top one is pinned (it becomes a bolt head), is used for screwing the bottom thread into the tool. There, clear as mud. Ian S C
                                        #102148
                                        chris stephens
                                          @chrisstephens63393
                                          Hi Mark,
                                          Don't be put off using Stainless in future because of a few difficulties making a M12 thread. I suspect you would have had similar problems cutting the same thread in Mild Steel, anything over about M10 can tend to slip in a chuck when using a die, depending on equipment available. Stainless does indeed have its little foibles but it is not that difficult to work, despite what some would say, and for me the ease of getting a near chrome like finish out weighs any troubles you might get drilling or die-ing. As for straight turning, you hardly notice any difficulties, save maybe having to take smaller cuts than leaded MS.
                                          So, if you don't like rust appearing on something you have just spend your hard won spare time on making, make it from free cutting 303 stainless. Don't, however, ever assume that that nice looking piece of SS is 303, there are some real swines called stainless out there and I suspect that most model engineers are put off using this very useful material by someone in the trade having a joke by giving a newbie a lump of useful looking of unmachineium.wink
                                          chriStephens
                                          #102154
                                          Jeff Dayman
                                            @jeffdayman43397
                                            Nice job Mark, looks well done. JD
                                            PS – I second what Chris says about grades of stainless – it is hard to make sure you have the real thing that you want. Dealing with a big commercial steel dealer is a good start. You can do a magnet test at the dealer for 300 series grades – a magnet should not stick to any 300 series stainless. You could take a file with you and if it files easily it is probably machinable. You can check how round it is with a caliper or micrometer, and observe the finish whether ground or rolled, is fit for your use. However, determing whether your stainless is 302,303,304,316 etc is much more difficult – spark tests of all these grades are almost identical, even detailed metallography which is involved and costly, well beyond most home shop builders, will not always ID these grades accurately. Probably best to go to a commercial dealer, ask for a scrap to do a machinability test on, go home and turn it, drill it, etc. if OK go back and buy qty you need. Even with commercial dealers there can be batch to batch differences and mis-identified steel.
                                            #102155
                                            MadMike
                                              @madmike
                                              Two observations from me which I hope will help you Mark.
                                              Firstly there are as many grades and alloys of Stainless as you can possibly think of. Each having its place in life and engineering. Many of the stockists of small/short ends do not know precisely what they are selling in this respect. Speaking as both an engineer and a motorcycle restorer I have found this out to my cost. Buy from a known dealer who can identify his stainless for you.
                                              Secondly, I am pleased that you have managed to make a tie rod, however as IanSC has pointed out you need to have a thread and lock nut at the "tightening end so that you can secure the shank of your collets etc. What you have made is only an elongated bolt as you have secured the "hammer/mallet" end by pinning. Ideally you need to have a loose collar to enter the end of the spindle and 2 lock nuts to secure the rod when tightened. With you design there is a risk that under some conditions the tie bar could become undone in use, for instance when stopping or reversing a spindle.
                                              Hope this helps.
                                              Michael
