Hi Guys,
If you are really stuck for a blade why not grind or mill down the next size up till it fits.It is perfectly possible to do the milling with a carbide end mill, as many of the members here now know.
A word of caution, because the edges are angled it is never quite the size you think. So check that you are measuring correctly.
chriStephens
PS. I was only milling a parting blade yesterday for the new design of parting holder. As I have said on other posts it does show great promise. I had great difficulty making it grab but once I did, all that happened was it slid the blade down out of harms way, instead of breaking it. Oh, and if you want to know how I got it to grab the answer was to not use any lubricant. The new, new version should help all the turners who think that the only way to part is with a rear tool post but do not have one. Further testing is required on a less than rigid lathe, unfortunately something I don’t have.
PPS the holder in the picture looks a reasonable design, just the right amount of top rake. Whether it is any good or not will show itself once a blade is obtained.
PPPS Before measuring the size of blade needed I hope you are moving the clamping block fully to the left , as the picture has it in the tightened position, at least it is if it is of the design that I think it is.
Edited By chris stephens on 10/01/2012 18:25:18
Edited By chris stephens on 10/01/2012 18:25:41
