Lathe tailstock
Lathe tailstock
Home Forums Model Engineer & Workshop Lathe tailstock
  • #314711
    Kenneth Widdall
      @kennethwiddall83506
      Hi l have a new barrel and nut for a Harrison tail stock which l got to replace the one in my 5/1/2 Harrison
      but never did so the barrel fits my old tail stock ok but the thread in the nut is different. dose any one know if the thread
      in the nut has been change.as l need to know it so l can sell it
      #38434
      Kenneth Widdall
        #314857
        David George 1
          @davidgeorge1
          Hi I have fitted new nuts in the past and there are at least two as some were metric and some were imperial.
          David
          #315259
          Kenneth Widdall
            Thank you for the reply's The nut in the barrel that l have must be metric as the imperil screw l tried would not fit. Ken
            #315262
              must be metric
              Sorry, but that assumption is flawed – if the previous reply is read correctly. There may be more than a single imperial thread used. Likely, but not certainly.
              #315314
              Kenneth Widdall
                Thank you for the reply's l will sell the barrel without a nut .
