Posted by Stuart Smith 5 on 11/01/2021 23:17:11:
Posted by SillyOldDuffer on 11/01/2021 21:51:56:
.A sunny day with a half decent breeze delivers far more energy than we need
Where does that info come from? As far as I can see, installed wind capacity is 24GW and installed solar is 13.4GW. That is installed capacity, not actual output. …
Don't confuse capacity with potential! Before canals and railways the energy obtained from coal was tiny despite a good part of the UK being sat on a giant coal-field. To benefit from coal it was necessary to build a lot of expensive infrastructure and to develop new technologies like electricity.
Green energy is the same. There is a development phase. New technology is expensive and unreliable at first, then it becomes cheap and reliable.
Rather than digging up and burning fossil fuels laid down hundreds of millions ago, green exploits solar energy directly. And the amount of energy delivered by the sun to the earth's surface is enormous – about 1.3kW per square metre. In total the Green energy potential is between 4 and 16 million Terawatt/hours per year. Forever.
Everything has pros and cons. On coal's plus side storage is trivial – it can be stacked in a heap – and power output can be controlled by throwing more or less fuel on a fire. Straightforward to manage with primitive methods. Coal also has many disadvantages; it has to be mined, cleaned, graded and transported. It's dirty to handle, tricky to burn efficiently. and the combustion products are polluting. Boilers are expensive to build and high-maintenance. As it took 200 years for the industrial revolution to put coal powered electricity into all UK homes, I think Green has made excellent progress. Although heavily subsidised at first, green today is the cheapest form of energy available in the UK. The 24GW wind and 14GW of capacity installed so far barely tap into what's available.
Cheap and plentiful but imperfect. (All technologies are imperfect.) The big problem with green is how to manage a source that comes and goes with the weather. At present green feeds into the grid and it's been possible to shut down coal generation almost entirely. This is good because the coal is imported from Brazil, Australia and the USA. But it can't replace everything. Green is flawed because it fades in and out at inconvenient moments. So the UK system relies on Nuclear, imported electricity, and Gas to cover the gaps. Effective electrical storage systems would eliminate gas as well, but there is no simple answer. Many options but they are all more-or-less high tech.
Mark's reference to Carnot suggested efficiency mattered, and I'm saying it doesn't in this case because the input energy is free and clean. Provided the infrastructure is affordable and stores a reasonable amount of power, running inefficiently on solar energy can be extremely wasteful without concern. Although the same system is completely uneconomic, wasteful and polluting when powered with fossil fuels, it makes sense when powered by Green energy. The rules change when one form of energy is substituted for another.
Edited By SillyOldDuffer on 12/01/2021 10:09:34
