RDG 30VSM-Parts Needed
Home Forums Help and Assistance! (Offered or Wanted) RDG 30VSM-Parts Needed
  • #33994
    Jasper Bower
      @jasperbower24283
      #590769
      Jasper Bower
        @jasperbower24283
        Hi,
        I have an RDG 30VSM which has mashed its gears. Could someone please point me in the direction of where to get replacements, please? Looking at the forum, it seems they are similar to the Warco WM16, but the gearing looks different? Thank You.
        https://www.ebay.co.uk/itm/113999695630
        #590817
        Dave Halford
          @davehalford22513
          Have you tried RDG ?
          #590820
          Jasper Bower
            @jasperbower24283
            I have emailed them and await a response.
            #590912
            Jasper Bower
              @jasperbower24283
              Unfortunately no joy. The answer was "we got them from the same places as Warco".
              #590919
              Ian Parkin
                @ianparkin39383
                Isn’t a 30 the same as a wm 18?
                if so i think i have a spare off to look now…
                #590922
                Ian Parkin
                  @ianparkin39383
                  Is it a 56 and a 31 tooth?
                  if so i have one
                  #590927
                    You can get an idea of what gears you require by measuring the OD of the mating gear, and counting the teeth, as well as the other dimensions..
                    The gears are likely to be Module, so Diameter in mm / (Tooth Count + 2) i= Module.
                    EXAMPLE
                    OD = 27.5 mm / (20+2 ) = 1.25 (Module ) for a 20 tooth 1.25 Mod gear.
                    The answer may well be 1.5, 1.25 or 1.
                    You could look at other importers to see if they import a similar machine (Possibly only in a different paint scheme) who could supply a replacement.
                    Likely places, once you have measured the gears, and knowing the tooth count of the damaged gear, might be Chester, Axminster Arc Euro, SPG, Amadeal etc.
                    Bear in mind that some machines, although superficially identical, may differ in detail. Depending on the manufacturer,, the keyway, for instance may differ, (Say 4 mm against 3 mm),
                    If all else fails and only the bore is different, you might have to bore out and bush a close approximation to get the machine running again.
                    Ultimately, you could approach someone like HPC, or Davall or Reliance gears, but their gears are likely to be costly and need modification to fit your machine.
                    The only other advice that I can give is not to work the machine quite so hard in future
                    The plastic gears are the weak point in the drive train and fail safe to protect other components, akin to a shear pin..
                    These are hobby machines, not industrial machines designed to be worked hard 8 hours every day!
                    #590946
                    John Baron
                      @johnbaron31275
                      When that gear got damaged on my mill, I went to HPC and bought steel gears and made my own replacement ! In my case quieter as well. The moulded gear was off centre and made a thumping noise as it ran.
                      #590984
                      Jasper Bower
                        @jasperbower24283
                        Posted by Ian Parkin on 21/03/2022 14:47:06:
                        if so i have one
                        The single Large Helical is 39. Large is 56 Fixed to 30
                        #590985
                        Jasper Bower
                          @jasperbower24283
                          Posted by Ian Parkin on 21/03/2022 14:39:42:
                          Thank You. I do not know!
                          #591252
                          Packmule
                            @packmule
                            Know anyone with a 3d printer ?
                            #591302
                            Jasper Bower
                              @jasperbower24283
                              Posted by Packmule on 23/03/2022 12:39:44:
                              Yes, if someone has the .stl files? That would be fantastic
                              #591612
                              Packmule
                                @packmule
                                If you look on thingiverse for G0704 gears there are both spur & helical listed , may fit
                                #591627
                                Jasper Bower
                                  @jasperbower24283
                                  Posted by Packmule on 25/03/2022 22:22:18:
                                  Thank you.
                                  #591632
                                  Jasper Bower
                                    @jasperbower24283
                                    Having no luck at the moment with gears, I am looking at fitting an AC motor with belt and pulleys. The current DC motor is 1100W, what is the AC equivalent please? Any links to suitable belts? Thank You.
                                    #591639
                                    Ian Parkin
                                      @ianparkin39383
                                      Are you sure on the fixed pair of gears?
                                      i have a set off a 30vsm spare and they are 31 and 56 and the helical is 39
                                      #591642
                                      Jasper Bower
                                        @jasperbower24283
                                        Hi Ian,
                                        I have messaged you. Thank You
                                        #591644
                                        Jasper Bower
                                          @jasperbower24283
                                          Posted by Ian Parkin on 26/03/2022 10:20:29:
                                          Having recounted. You are correct! that gearing is what I need. THANK YOU!!
