Unimat Fretsaw set up
Home Forums Help and Assistance! (Offered or Wanted) Unimat Fretsaw set up
  • #448449
    Chris V
      @chrisv
      Unimat Fretsaw No1080 arrived today, looks to be in good condition though needs a good oiling.
      If anyone is familiar with these, I'm not clear how the upper blade guide locks the blade?
      The part is a piece of rod with a slot cut down its length, then a VERY tight piece of tube at one end, also with a vertical slot. Currently both rod & tube are a very tight fit, I'm assuming they are meant to be movable against each other and should somehow clamp the fret blade in place?
      Any assistance as always gratefully received!
      Cheers
      Chris.
      #33519
      Chris V
        @chrisv
        Query regarding upper blade holder
        #448465
        Former Member
          @formermember19781
          #448473
          Chris V
            @chrisv
            Hi Bill, thank you, I have a general assembly diagram of how the saw components fit together, but it dosen't show how this part works, or is meant to. Maybe you have some more specific info, if that the case then yes please do send it over.
            Cheers
            Chris.
            #448475
            John Purdy
              @johnpurdy78347
              Chris
              If you attachment looks like this, the rod is just a guide for the blade. The blade is not actually fastened to anything at the top but just slides in the slot in the rod which acts as a guide. The tube on the rod is fixed and serves to retain the blade in the slot. In use the rod is moved down to just clear the work and is clamped to the frame at the top with the large knurled thumb screw. It is also orientated with the slot to the front so the cutting pressure pushes the back of the blade against the slot.
              Emgee
                @emgee
                Chris
                John Purdy has described operation perfectly, be sure to feel the cutting action in use and don't try to force the cutting speed.
                Emgee
                #448485
                Chris V
                  @chrisv
                  Thank you so much John and Emgee, yes mines like that so problem solved. I need to get some metal cutting blades now, what sort of TPI would be good for 1mm brass & copper?
                  Cheers
                  Chris.
                  #448766
                  Ian S C
                    @iansc
                    I got an Emco Unimat SL early last year, nice wee lathe , It came with attachments including the jig saw, no blades, I looked at fret saw blades, too thin, then I looked at coping saw too wide, so I took one and ground quite a bit off the back of the blade until it seemed to fit, it works OK. It seems OK even though there is nothing supporting the top end of the blade. If the going gets tough rub the blade with a bit of candle wax, You could grind down a junour hacksaw blade. Just got to find something to use as belts for the thing, I,m using 5 mm heat join belt.
                    Ian S C
                    #448775
                    Former Member
                      @formermember19781
                      #448803
                      Chris V
                        @chrisv
                        Thank you Ian, and I hope you continue to recover well.
                        Today some fretsaw blades arrived but agree I don't think they will perform well, unless under tension. Hopefully tomorrow I will have a chance to assemble it and try it out.
                        I'm currently considering if I might make an upper blade clamp so the blades can be in tension.
                        I'm sure Ive seen belts available on eBay.
                        Cheers
                        Chris
                        #448807
                        Former Member
                          @formermember19781
                          #448808
                          Chris V
                            @chrisv
                            Oh ok thanks very much Bill.
                            I think when I needed some I was just glad to find they were still available but that was some while ago, before I saw the light and joined the forum!
                            Cheers
                            Chris.
                            #448848
                            Hollowpoint
                              @hollowpoint
                              Posted by 34046 on 25/01/2020 13:33:37:
                              Posted by Chris Vickers on 25/01/2020 13:22:58:
                              Cheers
                              Chris
                              Currently listed on ebay at TWICE the price of Emco ones from Pro Machine Tools which is why I mentioned it.
                              Like for like rubber as opposed to poly.
                              Bill
                              Edited By 34046 on 25/01/2020 13:35:06
                              A set of 2 butyl rubber belts are £7.20 plus postage from pro machine tools.
                              A set of 2 polyurethane belts is £8 delivered from ebay.
                              Not twice the price, and polyurethane is superior quality.
                              #448871
                              Former Member
                                @formermember19781
                                #448872
                                Former Member
                                  @formermember19781
                                  #448906
                                  Hollowpoint
                                    @hollowpoint
                                    Posted by 34046 on 25/01/2020 19:20:10:
                                    The smaller one is the same price so £2.40 times times 2 equals £4.80 so not sure how you arrived at £7.20 ?
                                    Bill
                                    Edited By 34046 on 25/01/2020 19:21:09
                                    Edited By 34046 on 25/01/2020 19:23:41
                                    They both have Unimat SL's.
                                    Unimat sl large belt £3.60
                                    Unimat sl small belt £3.60
                                    £7.20 plus postage.
                                    #449003
                                    Ian S C
                                      @iansc
                                      There is a new (to me) machinery retailer in Christchurch NZ, that I must explore. I'm using the low ratio so it has 4 belts.
                                      Ian S C
                                      #449004
                                      Former Member
                                        @formermember19781
                                        #449037
                                        Chris V
                                          @chrisv
                                          Ok well I set the fretsaw up this morning and was pleasantly surprised with how it works.
                                          Cut 1mm copper and 1.5mm brass without much problem.
                                          Unimat Fretsaw
                                          Only issue I can see is if as suggested the top guide is lowered down to just clear of the work being cut, to act as both a hold down and blade support you cannot see where you are cutting. So that's something to think about..and any ideas are welcome.
                                          Cheers
                                          Chris.
                                          #449083
                                          John Purdy
                                            @johnpurdy78347
                                            Chris
                                            When I use mine I set the blade guide 1/16 – 1/8" above the work. This provides good support to the blade but allows you to see what's going on. It's not actually used as a work hold down (that's the job of your fingers!).
                                            Chris V
                                              @chrisv
                                              Ah thank you John ok I will try that, seems like I was over thinking it
                                              Not like me at all🤔😊
                                              Cheers
                                              Chris.
                                              #449096
                                              Chris V
                                                @chrisv
                                                Oh yes, what blades and where from please, I think the ones I got are probably too fine ….
                                                #449120
                                                Hollowpoint
                                                  @hollowpoint
                                                  I have one if these fretsaws for my unimat, well actually 2 but one is missing the d shaped arm. The other is practically brand new and came with an unopened packet of blades. The blades look like jewellers/piercing saw blades rather than the more common and slightly larger fret/scroll saw blades.
                                                  #449169
                                                  Chris V
                                                    @chrisv
                                                    Ok thanks, I will have to practice!
                                                    Cheers
                                                    Chris.
                                                    #587078
                                                    David E
                                                      @davide
                                                      Has anyone built a top tensioner for the Unimat Fretsaw, to allow the use of tensioned blades such as fret saw or even jewelers saw blades? I am interested in doing so, for sawing thin brass and other metals.
