Mystery French Medical ? Item
Home Forums Help and Assistance! (Offered or Wanted) Mystery French Medical ? Item
  • #366598
    Martin King 2
      @martinking2
      Hi all, Have had this for some time but had no luck finding out what it is for.
      it came from a French vide grenier last year and is very well made as can be seen. I thought it was for some sort anethstetic use as it has "CHLORETYLE BENGUE' alng with the usual Brevette SGDG marks.
      However there is no venting hole or vavle to the top, it just comes straight off so all contents would be gone in a flash?
      Any thoughts are most welcome.
      Cheers, Martin
      #33245
      Martin King 2
        @martinking2
        #366600
        Fowlers Fury
          @fowlersfury
          Ethyl chloride was and still is, used as a local anaesthetic e.g for piercing ear lobes and other bodily parts I prefer not to think about.
          Quite possibly that's not the original top/valve (brass different colour?).
          You can see a few 'antique' cylinders in Google Images>
            Martin,
            What an interesting device !
            After drawing blanks on various translation tools, and on google
            … I tried searching with DuckDuckGo, and would recommend that you do the same.
            https://duckduckgo.com
            Edited By Michael Gilligan on 10/08/2018 11:23:39
            #366604
            Martin King 2
              @martinking2
              Posted by Michael Gilligan on 10/08/2018 11:21:05:
              Martin,
              Michael. many thanks indeed, lots of info there including an exactly similar photo. Seems there were several different sorts of this device, i liked the one with different ends/nozzles.
              Cheers, Martin
              #366605
              Martin King 2
                @martinking2
                Fowlers Fury: many thanks for the link, top does appear to be original as per one of Micheal's links.
                Cheers, Martin
                #366606
                Martin King 2
                  @martinking2
                  Michael, FWIW this came in the bottom of a box of grubby scrap spanners! Wrapped in an old copy of a French newspaper!
                  Martin
                  #366618
                  Brian Wood
                    @brianwood45127
                    Martin,
                    I'm curious and don't want to explore on DuckDuckGo; I thought this was a drench tool or something similar.
                    What is it please?
                    Brian
                    #366619
                      As it boils at about 12.5C, perhaps it was partially filled with liquid which was allowed to evaporate and provide a mixture for general anaesthesia. A bit rough and ready by today's standards.
                      Martin King 2
                        @martinking2
                        Hi Brian, It is a portable way of allowing local anaethstetic to be administered, i guess by dropping it on a mask over the patients nose & mouth. I do not think it could last very long as it evaporates so fast?
                        PS whats a drench tool?
                        Cheers, Martin
                        #366627
                        pgk pgk
                          @pgkpgk17461
                          This would just be a storage tank.
                          I've only ever seen ethylene chloride used for it's evaporative cooling effect.. in dentistry on a pledgelet of cotton wool applied to teeth when unsure which is the sensitive one or sprayed topically prior to minor surgery.
                          This link to the anaesthesia journal describes it's general anaesthesia uses **LINK**
                          I'm guessing it would have been dripped onto a simple face mask. Indeed in my youth it was common for vets to anaesthatise cats for minor procedures using a pledglet of ether soaked cotton wool dropped into the bottom of either a golden syrup or fowlers treacle tin which had multiple piercings in it's base. The patient would inhale through that base and cotton wool and vapourise the ether. There is an art form in controlling mutiple feline weaponry with one hand while hanging on to the scruff and holding tin over face with the other.
                          After the procedure (typically a quick castration) the cat would be put back in it's basket and handed to the owner with instructions to drive home with the windows open a little – not enough for the cat to escape but enough to vent the cat's expirations lest the driver pass out.
                          pgk
                          #366630
                          Fowlers Fury
                            @fowlersfury
                            "As it boils at about 12.5C, perhaps it was partially filled with liquid which was allowed to evaporate and provide a mixture for general anaesthesia."
                            It was in common use as a GA at the beginning of the 20thC but even then only administered as a spray onto a gauze mask. It is a potent anaesthetic but the induction is rapid and dose/response very steep so easy to administer a lethal dose. Like all volatile chlorinated liquids it was found to cause cardiac sensitivity. As a young apprentice pharmacist I remember local jewellers coming to replace their empty glass vials for LA ear-piercing.
                            #366631
                            John Paton 1
                              @johnpaton1
                              Fowlers Fury – that is interesting and a little worrying. I use ether both for 'pepping up' stale fuel for model diesel engines and also in the form of easy start for petrol engines.
                              How much do you need to breathe in to cause a heart problem?
                              Cheers
                              David Standing 1
                                @davidstanding1
                                Posted by pgk pgk on 10/08/2018 13:00:53:
                                pgk
                                That made me giggle smile
                                #366640
                                  Posted by Brian Wood on 10/08/2018 12:26:45:
                                  Any special reason, Brian ?
                                  … Your comment has made me curious
                                  Edited By Michael Gilligan on 10/08/2018 14:17:45
                                  #366715
                                  Fowlers Fury
                                    @fowlersfury
                                    John Paton wrote: "that is interesting and a little worrying. I use ether both for 'pepping up' stale fuel for model diesel engines and also in the form of easy start for petrol engines. How much do you need to breathe in to cause a heart problem?"
                                    John,
                                    Ether (Diethyl ether) is not a chlorinated compound so the cardiac sensitising effect of methyl chloride (chloromethane) & other chlorinated solvents isn't an issue for you. (Explosion risk is another matter !)
                                    Pedantic P.S. for Neil, boiling point of chloromethane is: -24.2°C
                                    #366729
                                    mike T
                                      @miket56243
                                      I was once clever enough to flatten my thumb with a hammer blow, made a right mess of the thumb nail.
                                      A medic at the local RN base treated my injuries. He had a small glass bottle of chloromethane which expelled a jet of the liquid as the liquid inside the bottle boiled off. The medic directed the jet ot liquid chloromethane at my damaged thumbnail. Intensely cold at first but I soon lost all sensation, moments later he removed the complete thumbnail. All over and done within a few minutes, I did not feel a thing.
                                      He said I was lucky, in a previous era I would have been given a piece of wood to bight on instead.or perhaps a tot of rum.
                                      #366731
                                        Posted by Fowlers Fury on 10/08/2018 20:55:48:
                                        Pedantic from me – we're talking about chloroethane not chloromethane…
                                        Brian Wood
                                          @brianwood45127
                                          Michael G
                                          I picked up a computer bug from somewhere recently, despite the care taken with firewalls and the like and I was doubtful about the name DuckDuckGo—-there was no other reason
                                          Martin King 2
                                          A drench is I believe a flushing device to which a piece of hose is attached and used as the name implies for irrigation purposes; it was the cross handle on top of your device that led me to thinking it might be a one shot pump action applicator.
                                          Vets also apply a drench to cattle and other ruminants by pouring the mixture down a rubber tube with a filling funnel attached, the mixtures are mostly for re-hydration
                                          Brian
                                          #366765
                                            Posted by Brian Wood on 11/08/2018 08:52:38:
                                            Michael G
                                            Thanks for the clarification, Brian
                                            Due caution is always advisable, given the world we live in.
                                            To the best of my knowledge DuckDuckGo is simply a very good search engine, built by people with very good intentions. … I like it a lot.
                                            If you are still comfortable using Wikipedia, may I suggest that you look at this: **LINK**
                                            https://en.wikipedia.org/wiki/DuckDuckGo
                                            Fowlers Fury
                                              @fowlersfury
                                              "Pedantic from me – we're talking about chloroethane not chloromethane…"
                                              Mike., mea culpa and apology.
                                              In mitigation, I was schooled in the old chemical nomenclature of methyl/methylene, ethyl/ethylene, propyl/propylene etc followed by the attached halogen radical. Before my retirement IUPAC decided to change it all by putting the radical first & calling them halogenoalkanes. So ethyl chloride became chloroethane and so on. Aged brains like mine had to cope with usage of both names, often leading to carelessness as in reading the b.p. of chloromethane instead of chloroethane. (Unless watched, spell checkers will “correct” one’s “errors” as typing this has proven).
                                              It has become worse I fear, since once familiar names are now described as obsolete !
                                              For example acetylene is now ethyne (not to be confused with ethene, previously known as ethylene) and acetone is now propanone.
                                              #366799
                                              pgk pgk
                                                @pgkpgk17461
                                                Posted by Brian Wood on 11/08/2018 08:52:38:….
                                                Vets also apply a drench to cattle and other ruminants by pouring the mixture down a rubber tube with a filling funnel attached, the mixtures are mostly for re-hydration..
                                                Also pedantically as a point of order <s>..
                                                A link to Black' Vet Dictionary **LINK**
                                                While to drench means to soak in veterinary terms it simply refers to (forcibly) dosing (farm) animals with liquid medicines often simply with a dosing gun as when i give my sheep parasiticides. Considering a decent sized cow will have a stomach volume of some 55 gallons trying to rehydrate something like that by oral tube is a tad pointless unless you've caught it early enough that it doesn't need doing. About the only time substantial oral volumes were dosed in my time was with surfactants or alkalis etc in suspected bloats and ruminal acidosis when we're still talking a pint or so. Nowadays they flog various rumination aids lke probiotics – nowhere near as effective as the (no longer available) ginger, stychnine and ammonia mix.
                                                Fowlers Fury
                                                Does that mean we are soon to use OH2 or shall it be O0.5H ?
                                                pgk
                                                #366824
                                                Fowlers Fury
                                                  @fowlersfury
                                                  "Does that mean we are soon to use OH2 or shall it be O0.5H ?"
                                                  It's "the pot calling the kettle etc" after my misnaming Neil as Mike above sad
                                                  so I must desist from pouring further scorn on IUPAC*.
                                                  Nevertheless a final few examples for us aged chemists:-
                                                  Ozone is now trioxygen
                                                  Glycerine is now propane- 1,2,3-triol
                                                  Acetic acid is now ethanoic acid
                                                  (iso)octane is now 2,2,4-trimethylpentane
                                                  *International Union of Pure & Applied Chemistry.
