Warco WM-16 Motor Speed Fluctuation.
Home › Forums › Electronics in the Workshop › Warco WM-16 Motor Speed Fluctuation.
Viewing 25 posts - 1 through 25 (of 28 total)
  • #641363
    Ed Duffner
      @edduffner79357
      Hello Guys (and Ladies).
      For a while now my Warco WM-16 milling machine has suffered a motor speed fluctuation issue and sometimes just twitches or won't run at all. The machine uses the stock motor controller and DC brushed motor. New motor brushes have been installed.
      When the motor doesn't run I can turn the spindle by hand safely a few degrees, unpowered, then restart and sometimes it will work. When running, the motor can be stable for a few minutes then suddenly increase or decrease speed or even run down and stop completely.
      Searching the web I'm given to understand that speed control is handled by the SCR's and Diodes on the controller PCB. Is this correct? None of the ones on my PCB appear to be burnt out or overheated. I was also suspecting the speed sensor which I think is an optical device working through a holed flange mounted on the spindle.
      If the SCR's and diodes are the likely cause, can anyone kindly verify if these parts from Mouser are ok to use? I believe the 'L' in the part numbers refers to the necessary isolated tabs?
      S8010LPT as a replacement for the A69108.
      D8010L
      Thank you,
      Ed.
      Second time posting this. Microsoft Edge won't allow the SCAYT spell checker to close and all typing is lost. crook
      Edited By Ed Duffner on 15/04/2023 15:55:07
      #32335
      Ed Duffner
        @edduffner79357
        Do I need to replace the thyristors/diodes?
        #641371
        John Rudd
          @johnrudd16576
          As usual we jump in with both feet…..frown
          My suspicion is with the motor, specifically the armature…either a bad segment or a poor contact leading to an open circuit winding.Check carefully at the commutator with a magnifying glass. You can check the continuity with an ohm meter…between the comm segments, the readings should be equal.
          Firstly, check the speed controller by disconnecting the motor, then connect a 100Watt domestic incandescent light bulb in its place across the motor output terminals….The bulb should light up and be dimmable, every time you operate it…Do this many times, to prove its reliability.
          If you feel able, strip out the motor, strip it down ( mark the motor end pieces relative to the main body! ) clean up the commutator with sandpaper, nothing else! Give it a wipe with a dry cloth and reassemble…
          Check the brushes move freely in their boxes..
          Put the motor back and try it again.
          I’ve repaired many of these controllers where the motor has been the culprit every time….and repair isn’t cheap ( neither is a replacement)
          So start with the simple things before reaching for the soldering iron…
          #641399
          Andy Stopford
            @andystopford50521
            Weird behaviour like this can be caused by a dodgy speed control potentiometer – it will of course work perfectly when you try checking it with a meter, so easiest just to test by substitution, they're cheap enough.
            #641400
            Ed Duffner
              @edduffner79357
              Thank you John, I went ahead and removed the motor, my day job is a service engineer for power-tools and small plant, armatures are generally replaced rather than repaired. The comm' segments are all flat and sound. I have cleaned them though with 1200 grit emery and IPA to remove any carbon dust, I think sandpaper is a little course.
              Anyway, checking adjacent segments they measure 0.5Ω all the way around except for where the ends of the coil comes together. The two neighboring segments to the joint read about 1.1Ω an I can very slightly move the wire ends. I will see if I can gently crimp the joint back into place and retest.
              The brushes are free to travel in their holders.
              Tomorrow I'll see if I can test the controller with a lamp.
              Andy, that's a good point about the pot', thank you sir.
              Ed.
              #641411
              John Rudd
                @johnrudd16576
                Weird behaviour by the pot would show up with the lamp test…
                #641468
                Ed Duffner
                  @edduffner79357
                  Ok, a few minutes ago I made a video of the lamp failing whilst connected to the motor wiring. It would appear to me that there is a fault with the controller output.
                  The lamp used in the video is a standard 60Watt, I do not have a 100Watt lamp.
                  #641470
                  SteveW
                    @stevew54046
                    When my lathe (WM250) developed very similar symptoms I found that a resistor on the control board was not seated correctly. Once pressed in all back to normal.
                    Picture in album (of course may be different control board!)
                    Steve
                    #641474
                    Ed Duffner
                      @edduffner79357
                      Thanks Steve, it looks like the same board. I pushed in that resistor yesterday to make sure of that, it was another thing I found on the web. I think I need to remove the board completely and look for dry joints etc.
                      Cheers,
                      Ed.
                      #641742
                      John Doe 2
                        @johndoe2
                        Looking at the bulb demonstration, that looks very much like a dry joint or bad joint somewhere, as you suspect.
                        Doesn't seem to be an output stage problem, because the brightness is only varying very slightly – if an output stage was faulty, I would expect the bulb to be going to half brightness or off. i.e. a major difference. What we are seeing seems to be a minor difference, so I suspect a fault in the drive to the output stages, and would look around the speed control area of the board – start with the speed potentiometer itself, it might have a dirty or damaged track.
                        First thing to do is clean all connections with switch cleaner spray; so any wires held in terminal blocks, or ribbon cables or plugs joining the PCB. Then get some spray into the speed pot and exercise the pot over its full range, backwards and forwards. Allow to fully dry before testing. Then any integrated circuits held in sockets – be extremely careful if you have not removed ICs before, and earth yourself to avoid static discharge. Then resolder the solder side of the whole PCB in case of dry joints.
                        And then change all the electrolytic capacitors – they can dry out and stop being capacitors, which prevents the circuits they are in from working properly. If none of that helps, you will have to start fault finding the PCB at component level.
                        Apologies if I am teaching you to suck eggs !
                        Edited By John Doe 2 on 18/04/2023 10:06:53
                        #642167
                        Ed Duffner
                          @edduffner79357
                          Thank you John Doe 2, I hope to have another look at this tomorrow (Saturday). You have pointed out some additional things to look out for and action where necessary, very much appreciated, as is all the input.
                          Ed.
                          #642249
                          Ed Duffner
                            @edduffner79357
                            Had another look at this today. Found a corroded resistor on the power board, it's a 220KΩ and reads constant when tested with an ohm-meter, actually 223KΩ. I suppose it might be different when powered on and I will change it anyway. Below are some photos, of the power board and speed controller board?
                            All solder joints appear to be sound. I have yet to test the speed potentiometer and start cleaning socketed and plug-in components.
                            #642252
                              I don't think the 220k resistor is the cause – it appears to be part of the mains filter circuit, which would carry on working even if it was removed. I'd leave it alone.
                              It and the two rusty Allen head bolts on the heat-sink suggest condensation, but it could have happened in factory storage, as the rest of the it looks clean. Is condensation a problem in your workshop? It plays merry hell with electronics, causing all manner of weird faults. Rusty heat sink bolts might cause trouble if SCR1 and D15 where insulated from the heat-sink with a mica washer but they seem to be bolted straight to ground (normal).
                              Diagnosing fault electronics gets up my nose even though I have the gear. I'd replace the board if I couldn't quickly trace this to the pot, it's connections, or something obviously amiss on the board. Others have more patience!
                              Ed Duffner
                                @edduffner79357
                                Dave, yes condensation has been bad in my shed over the years. I now have 2 tubular heaters behind my lathe and mill. It's strange that it might have caused just two of the screws to rust? The nuts holding the power board to the casing are also corroded but not the screws, unless they are stainless of course.
                                Ed.
                                #642456
                                John Doe 2
                                  @johndoe2
                                  Does C101 have a bulging end? Hard to tell. I might also very carefully mark, then gently exercise those five blue pots; "Min Max" etc. It is possible that one of them has a dodgy contact with its track – especially if they might have been damp over time.
                                  Put pairs of dots somewhere on each moving white part and the body with a permanent marker as a reference to get them exactly back to where they were. Probably not too critical.
                                  Edited By John Doe 2 on 24/04/2023 17:07:25
                                  #642547
                                  John Doe 2
                                    @johndoe2
                                    By the way, only move or clean the pots etc with the power switched off – never with the circuit live.
                                    #642556
                                    Dick H
                                      @dickh
                                      I don´t know whether this is useful but could it have something to do with the set-up pots given that there was a bit of humidity.? (Manual for similar board)
                                      #642578
                                      Ed Duffner
                                        @edduffner79357
                                        C101 is ok, I can see what you mean though it does look bulged, just the way the light is catching the markings in the cap.
                                        I will check the preset pots. I just received some electrical contact cleaner, ok for pot wipers too although the presets do seem to be very well sealed. All maintenance will be performed on a dead board.
                                        Dick H, Many thanks for the manual link, that certainly is a lot of info to digest.
                                        Ed.
                                        #642580
                                          Picking up on John Doe's comment about dry joints, have a good look at the soldering and PCB tracks with a strong magnifying glass, both sides of the board.
                                          Dry joints have a characteristic grey crystalline look rather than being shiny metallic. I've never seen one on an SMD board – the tiny components – but they seem more likely on wired components that go through the board like the big resistors, capacitors, connectors, etc.
                                          Broken tracks are harder to spot – sometimes they develop a hairline crack that opens and closes randomly as the board heats up or is vibrated by the motor.
                                          Both fixed by a dab of fresh solder. The track will have to cleaned back to copper first, which is a delicate operation requiring a steady hand and a scalpel. May be easier to trace the track back to something easier to solder to and bridge the whole section with a wire. Depends on the board – modern ones are often tightly packed with tracks running within a fraction of a millimetre of each other, not meant to be repairable.
                                          Andy_G
                                            @andy_g
                                            Posted by Ed Duffner on 22/04/2023 17:06:33:
                                            …I have yet to test the speed potentiometer…
                                            I would very strongly urge you to do that before doing anything else with the boards!
                                            As above – just replace it. They are 'wear parts' and don't last forever.
                                            #647398
                                            Ed Duffner
                                              @edduffner79357
                                              Just a quick update on this one. I've been waiting for a potentiometer from China which arrived this week. Fitted it all back together with a new pot' today …and still the same.
                                              Oh well, back to the drawing board as they say.
                                              Ed.
                                              #647399
                                              John Haine
                                                @johnhaine32865
                                                One common factor throughout the time I've been a member here is the poor reliability of these DC motor speed controllers. They are badly designed and made down to a price. I think personally it would be best to junk the controller and replace it with a genuine KB Electronics one or similar – or perhaps replace the motor with one of these nice brushless sewing machine motors and controllers.
                                                #647400
                                                Richard Marks
                                                  @richardmarks80868
                                                  I had a similar problem and it was caused by the new brushes, I would advise you to file the ends of the brushes until they are solid, get rid of the slitting and marking and make the ends curved to fit the commutator and they slide easily in their holders
                                                  #647404
                                                  noel shelley
                                                    @noelshelley55608
                                                    To round the ends of the brushes make up a round bar the same dia as the com cover with a strip of wet or dry and spin it. Offer the brush to it true and square, job done. Noel.
                                                    #647415
                                                    duncan webster 1
                                                      @duncanwebster1
                                                      There must have been hundreds of posts about failures of these boards. With the talent we have out there (not me) it must be possible to design a bomb proof board that could even withstand bring short circuited. Mount it in a metal box with a very low wattage heater. It would be a bit more expensive than the original, but buying one which then lasts for ever is cheaper than replacing the cheap, despite what the accountants will tell you
