Free Cutting Mild Steel Flat
Home Forums Materials Free Cutting Mild Steel Flat
  • #574894
    Thomas Gregory 1
      @thomasgregory1
      I need some 2"1/2 x 1/2 flat mild steel which I need to bore a hole and put a radius on the flat corners (if that makes sense) using the lathe. I see lots of EN3B about but is there anything else that may be suitable?
      M-Machine sell EN8 and EN32B but searching looks like there's a lot of issues machining these?
      Many Thanks
      Tom
      Edited By Thomas Gregory 1 on 10/12/2021 12:55:47
      #30188
      Thomas Gregory 1
        @thomasgregory1
        #574895
          EN3B is not a problem to machine and should cut easily and give a good finish, I use it a lot on my fabricated engines.
          #574898
          Thomas Gregory 1
            @thomasgregory1
            Just what I wanted to hear, thanks.
            #574904
            Bo’sun
              @bosun58570
              While vaguely relating to this thread, has anyone come across a "succinct" comparison chart of commonly used steels in model engineering with EN numbers, properties, machinability, etc, and cross reference to current specification numbers.
              #574911
              Thor 🇳🇴
                @thor
                Posted by Bo'sun on 10/12/2021 14:46:08:
                Something like these maybe?
                ***Link***
                ***Link*** (uses old EN numbers, analysis and use)
                ***Link*** (compares various standards)
                ***Link*** (machinability)
                Thor
                Edited By Thor 🇳🇴 on 10/12/2021 16:21:26
                #574916
                Bo’sun
                  @bosun58570
                  Thank you Thor,
                  That's just the sort of thing I had in mind. Just need to get my head around the "% machinability index".
                  #574930
                  Vic
                    @vic
                    Is there a machinability index for common stainless steels? Good links by the way Thor. wink
                    #574933
                    Thor 🇳🇴
                      @thor
                      Posted by Vic on 10/12/2021 17:49:13:
                      A few links, I have only tried the austenitic stainless steels and 303 is easier to machine than 316:
                      ***Link***
                      ***Link***
                      Thor
                    Home Forums Materials Topics
