Bottom item (long tapered tube) is a blow pipe, used in conjunction with a methylated spirit lamp to heat small items (eg jewellery) for hard soldering. Could also be used with a bunsen burner to direct a very small very hot flame sideways out of the main flame. Also used for heating precious metal ore for assay on a charcoal block.
Top item is a spirit burner, fill it with methylated spirit and light the wick. The flexy rubber tube with a pretty shaped (ivory?) mouth piece is missing, would attach to the bottom of the curved blowpipe tube.
To use either convincingly you need to learn the wood-wind player's discipline of being able to blow out down the tube using air stored in you mouth whilst at the same time inhaling via the nose.
HTH Simon
PS Late to the party as ever, someone came to the door and I was pipped to the post. Story of my life.
Edited By Simon Williams 3 on 28/12/2021 12:38:31
