STEAM ENGINE VALVE LEAKS
Home Forums General Questions STEAM ENGINE VALVE LEAKS
  • #27373
    oscar blauman
      @oscarblauman34278
      oscar blauman
        @oscarblauman34278
        I have just completed a Stuart N1 engine which works well under compressed air.
        It does leaks considerably when the valve position is such that I would not expect any air to come out from the exhaust. I did spend considerable time polishing both the cylinder wall and the valve bronze sliding part, they are almost mirror like now, without any measurable difference. I would like to know how good of a seal the valve should make to be considered good enough and if there is something else I should be looking at other than the good mating of the surfaces, thanks oscar.
        #472964
        Derek Drover
          @derekdrover32802
          Hi Oscar
          With sliding valves, both faces not only need to be to a good polish, but they need to be flat. If you've not used a flat surface to polish on you may create slight gaps.
          Also, are you running it dry or with a little oil applied? I'd try adding a little steam oil and see if that helps seal things up.
          Rgds
          del.
          #473000
          Redsetter
            @redsetter
            Assuming the contact faces are reasonably flat, the seal will gradually improve as the engine is run in. A fine matt finish is preferable to a highly polished one. I usually finish the valve and port face by rubbing on fine wet and dry paper laid on a flat surface. Do not run it without oil.
            #473012
            MichaelR
              @michaelr
              Have you got a little bit of float on your slide valve buckle ? which will allow the steam/air pressure to seal the valve to the port face.
              MichaelR.
              #473018
                As Michael says any tightness of the nut in the groove,valve rod in the cross groove or a wonky thread can stop the valve finding it's own position on the port face, you want it free but not sloppy
                I don't polish of flatten any of my engines, just run them straight away with the machined finish.
