Lanz tractor
Lanz tractor
Home › Forums › General Questions › Lanz tractor
  • #419588
    john brown 17
      @johnbrown17
      Oh Joy ,been thinking ahead as l need a bearing for another job ,it turns out that apart from 4 of the bearings on the lanz model ,the rest of the bearings are not off the shelve type grrrrrrr ,so looks like it going to be oil light or bronze bushes so advice would be most welcome please,of to find another room with no light .
      john
      #26722
      john brown 17
        @johnbrown17
        Bearings
        #419601
          It's not ideal to machine oilite particularly a small internal bore so best to use bronze, SA660 would be the ideal choice and machines better than others.
          It is possible to turn the outside of Oilite bushes with very sharp HSS or a **GT tip but reaming the inside will not give a good internal finish.
          #419611
          john brown 17
            @johnbrown17
            Thanks jason for that info,will bear that in mind for the future ,have been chatting to the firm l use for bearings and for once a local firm ,now l can get over more of the bearing sizes by using imperial and then machine to fit ,so apart from a couple of bearings that will have to be bronze ,and yes jason will use SA660.It would be nice to get drawings with bits on the shelve ,but then it would be to simple,plus the drawings were free,but am plugging away,thanks for your time.
            john
