Boll aero 18 internet drawings
Home › Forums › I/C Engines › Boll aero 18 internet drawings
  • #2653
    geoff walker 1
      @geoffwalker1
      Ron Chernich drawings
      #643190
      geoff walker 1
        @geoffwalker1
        HI all,
        I'm looking to make a start on this engine, but before I do an enquiry about the Ron Chernich drawings on the internet.
        I have many questions about this engine and the drawings which I will ask in due course.
        For now though just one about Ron's drawings. Are these drawings generally speaking "good to go" i.e. no major issues or omissions.
        Any comments most welcome.
        Geoff
        #643193
        Ramon Wilson
          @ramonwilson3
          Hi Geoff,
          Like any drawings – including my own – and despite best efforts on the part of the draughtsman mistakes can, do and will happen.
          Ron's drawings were usually pretty good overall though as said you may find the odd anomaly here and there.
          There's been many Boll Aero's made overtime – I don't recall hearing of anything that will prevent you making a good example – good luck with ityes
          Tug
          #643215
            You could always PM Chris Boll, he is a member.
            #643300
            DiogenesII
              @diogenesii
              I used those same drawings to build mine and don't recall having any real issues, it was fun to do and in spite of being my first experience of any kind with CI engines was quite easy to get going and (still is) a nice runner.
              #643429
              geoff walker 1
                @geoffwalker1
                Hi Gents,
                Thank you for your replies.
                My gut feeling was that Ron's drawings would be reliable, but nice to have that confirmed
                I'll keep posting on this thread with progress as I go along and of course I will have many questions.
                Thanks again Geoff
                Not sure about some of the "americanisms" on Ron's drawings. A cylinder MUFF, MUFF? MY Nan used a muff and I muffed a lot catches playing cricket, but an engine part!!!!!!
                #652864
                geoff walker 1
                  @geoffwalker1
                  Hi All
                  Well I'm making a start on this engine, so more questions to come.
                  I' intend to do all the machining on the sherline lathe which is fine for most of the parts.
                  I decided to bore out the crankcase using the four jaw chuck. The length of the case was I thought a problem as supporting the work would be difficult. I therefore decided to to split the case into a lower and upper half to make the machining more manageable. The lower half has a recess to accept a register ring on the upper half.
                  I'll need longer head bolts as the threaded anchor points will be in the lower half of the case with clearance holes in the upper half. The register is a very snug fit but I still plan to silicone seal the joint on assembly.
                  More post in due course hope this is of interest
                  Geoff
                  #652879
                  Ady1
                    @ady1
                    Ron was a cool guy and is missed
                    geoff walker 1
                      @geoffwalker1
                      Hi All,
                      Ron's drawings show three options for the crankshaft. This is one of them which I believe is Chris Boll's original design.
                      I like this one and will probably use it.
                      Ron points out that using this design "may" result in a "thrown prop". What is a thrown prop?
                      With particular reference to this engine has anyone any ideas how this design may result in a thrown prop.
                      I'm just curious, the design seems sound to me but perhaps I'm missing something?
                      Geoff
                      #653352
                      Ramon Wilson
                        @ramonwilson3
                        Hello Geoff,
                        A 'thrown prop' is when the prop becomes loose – usually when flicking to start it. The engine comes up on compression and the force loosens the prop nut. For the most part it's just a matter of retightening it but if it occurs a lot it's best to redesign the prop driver to something more practical. Some commercial engine shafts have straight knurling with the prop diver forced on, others a slotted drive but the easiest to make and sound in design is the tapered brass collet in a taper bored prop driver – the taper needs to be an exact match though for optimum drive.
                        It is said that throwing a prop can lead to the engine having a shaft run – ie the prop coming off and the engine continuing to run totally unloaded but having hand started engines for so many years and throwing props on many occasions I've yet to experience that happening. Indeed in 65 years of playing with diesels I've yet to meet anyone who has!
                        I have some pics of the taper collet system so I will upload them for you
                        Best – Tug
                        Edited By Ramon Wilson on 23/07/2023 12:17:22
                        #653360
                        Ramon Wilson
                          @ramonwilson3
                          Geoff – here are six pics from my ETA build described on MEM (I think)
                          Boring the prop driver blank with the topslide set at the required angle
                          Reverse turning a taper mandrel with the topslide unmoved
                          Holding the blanks on the mandrel to knurl the front face
                          Revers turning the brass collet
                          Finished items. The collet must bear against a shoulder on the crank shaft to resist the tightening forces. The step cut in the rear face of the collet is to enable a small lever to prise it off. No step – very difficult!
                          Hope that helps
                          Tug
                          Edited By Ramon Wilson on 23/07/2023 12:27:32
                          #653361
                          geoff walker 1
                            @geoffwalker1
                            Hi Tug,
                            Thanks for your reply.
                            I can see how a collet driver will be locked very tight on the shaft.
                            If the driver is not REALLY secure on the shaft then it may shift marginally and loosen the nut. Does that make sense?
                            In the design above the driver is screwed onto the shaft and then presumably it locks in place when it butts up against the end of the shaft, but perhaps not secure enough to prevent it coming free and loosening the nut.
                            After your comments I'll look at the collet option in Ron's drawing
                            Thanks again Geoff
                            Good project this I'm enjoying it!!
                            Edited By geoff walker 1 on 23/07/2023 12:42:02
                            #653362
                            geoff walker 1
                              @geoffwalker1
                              Hi Again Tug,
                              Just seen the pictures.
                              Excellent thanks
                              Geoff
                              #653363
                              KEITH BEAUMONT
                                @keithbeaumont45476
                                Well; Tug I can make your day! A few years ago, when I was test running the Sparey 5cc Diesel, I had just such an accurance. Engine back fired on start up, Prop spun off, but engine continued to run without the prop,but clockwise. I stopped it by shutting the needlle valve. I had not heard of such a possibility and like you have no knowledge of anyone else having it happen.
                                The Boll-Aero 1.8 drawings have no problems. I made the crankshaft to accept the collet /driver/
                                Keith
                                #653366
                                Ramon Wilson
                                  @ramonwilson3
                                  Well how about that Keith – on a side port engine too!.
                                  The only time I saw – more like heard – a shaft run was at a Nats when a speed model clipped the deck shearing both prop blades – the instantaneous increase in revs was something to be witnessed but no, never heard of one occurring when being started.
                                  There is a well know pic of someone starting a control line aerobatic model at a major competition the camera capturing the exact moment the prop is spinning off the engine shaft about 2 inches in front of the model and the revolutions caught in three distinct turns in front of the person starting it
                                  Geoff – if you are able to incorporate it the tapered collet system is the best of all allowing tight grip but easy removal. The angle wants to be 15 – 20 degrees (30 to 40 inclusive) too fine and it can lock. Don't make the collet from ali as it will in all probability gall and bind solid
                                  Keep on enjoying yourself smiley
                                  Tug
                                  #653802
                                  geoff walker 1
                                    @geoffwalker1
                                    Some more progress today.
                                    After some initial milling, shaping and drilling, set up the con rod on the Sherline.
                                    Perfect for the smaller items.
                                    Last photo shows it alongside the head, finished after some nibbling on the mill and some judicious filing.
                                    Geoff
                                    #653805
                                    geoff walker 1
                                      @geoffwalker1
                                      When I made the "firefly" some years ago I used EN8M for the crankshaft and the cylinder liner.
                                      I assume that the same will be ok for this engine but of course I am open as always to advice.
                                      I will need to place an order soon from M metals.
                                      Geoff
                                      #653820
                                      Ramon Wilson
                                        @ramonwilson3
                                        Hi Geoff,
                                        I've only ever used En24t for the cranks in my attempts but they are much larger of course. I would think En8M would be fine.
                                        With a cast iron piston the best material for an unhardened liner is plain old leaded mild steel (FC En1a). Easier to machine to a fine finish, laps well and is a great running combination with CI.
                                        I made eighteen scaled up 5cc diesel engines in total, the first had a cast liner and though still good compression after running it soon lost that 'firmness' of the initial set up. The second had a liner made from a tough steel (CR8) which proved very testing machining the ports with home made tooling.
                                        I then read an article about using 'cast in steel' as a set up for diesel or glow engines using leaded mild steel and made all the others in that fashion. None were hardened (by case hardening) and all proved to give excellent and lasting compression. (You should try hand flicking one of the Hunterslaugh)
                                        Again nothing wrong with using EN8 – just wouldn't use it myself.
                                        Hope you've got plenty of fuel – it's getting harder to source these days and quite expensive for what it is.
                                        Best – Tug
                                        #658399
                                        geoff walker 1
                                          @geoffwalker1
                                          I bought this rotary table about 4 years ago. I had to tweak it a little before the first use but since then it's had lots of use and I've been really pleased with it. I added a circular alloy table to make it easier to mount chucks and other attachments. The chuck in the picture is an Indian Zither, bought from ARC, again about 4 years. 4 jaw self centring, very accurate and for the price I paid good value.
                                          Both seen here in use milling the transfer channels and drilling the port holes in the Boll Aero cylinder. The cylinder is made from EN1A mild steel.
                                          Progress has been ok, here is another picture of some completed parts.
                                          The cylinder head screw for adjusting the contra piston is made to the sizes in Ron's drawings. I have seen some engines like this one which have a locking lever on the head presumably to secure the position of the screw and the optimum compression position for the contra piston. My feeling is that the lever is a good addition as when the engine is running (if the engine runs!!!!) there may be a possibility that the screw may vibrate loose and lose the setting? Any thoughts.
                                          Geoff
                                          #658419
                                          KEITH BEAUMONT
                                            @keithbeaumont45476
                                            Hi Geoff, It really depends on whether you are going to put the engine in a model that will fly. If so, it might be a good idea to be able to lock the compression, but if you are just going to run it on a test stand, I personally would not bother. You will be adjusting compression as you enjoy hearing it run.
                                            Keith.
                                            #658420
                                            geoff walker 1
                                              @geoffwalker1
                                              Hi Keith,
                                              Thanks for the reply.
                                              I think it's unlikely to go airborne, maybe, …but unlikely.
                                              So I'll leave it as it is for now
                                              Thanks Geoff
                                              #658423
                                              KEITH BEAUMONT
                                                @keithbeaumont45476
                                                Hi Geoff, It is all looking good ,so you are not far off hearing its first cry!
                                                Keith
                                                #658426
                                                Ramon Wilson
                                                  @ramonwilson3
                                                  Yes looking good Geoff hope you've got plenty of fuel wink
                                                  I agree with Keith that unless you are going to use it in anger so to speak a comp screw lock is not essential but handy if the engine does show a tendency to back off compression whilst running.
                                                  Vibration is usually the cause but a less than ideal fit on the contra piston doesn't help either. A small mod that helps is to drill the end of the comp screw to give a circular land rather than a potential point contact. Doesn't have to be deep just deep enough.
                                                  Good luck with the final phase
                                                  Best – Tug
                                                  #658483
                                                  geoff walker 1
                                                    @geoffwalker1
                                                    Hi Thanks again Gents,
                                                    More progress reports in due course.
                                                    I need to make another fixture to hold the piston while lapping into the cylinder, like this one I used on the firefly.
                                                    Cheers for now
                                                    Geoff
                                                    #658688
                                                    chris boll 1
                                                      @chrisboll1
                                                      Regarding the crankshaft of the BollAero 1.8cc, my original had the prop driver screwed onto the shaft, this was the same as the ML Midge which inspired my engine design.
                                                      The small Sparey diesel also used this method. Ron Chernich drew the other alternative versions.
                                                      My aim was simplicity above all, the engine was originally published in Aviation Modeller magazine, which was not read by experienced model engineers, in general.
                                                      Ron also swapped sides of the exhaust and intake from my original, I prefer my original way for upright installation in a plane.
                                                      All my engine plans are now on the Outerzone website, with the magazine articles for the AMI 1.8 and 4.4cc.
                                                      The 7.5cc diesel is not included as I haven't got around to doing an assembly drawing, but three engines have been built from the component drawings and run well.
                                                      I have been very pleased that the 1.8cc has been made in many countries including Finland, Mexico and Argentina and all of these can be seen on YouTube
                                                    Home › Forums › I/C Engines › Topics
