Turning paxolin
Turning paxolin
Home › Forums › General Questions › Turning paxolin
  • #25945
    Roger Hart
      @rogerhart88496
      #350736
      Roger Hart
        @rogerhart88496
        Been making a couple of disks from 1/4 inch paxolin. The tool traverses from right to left and as it leaves the left hand side a small amount of delamination takes place. Not serious for this application just not a tidy job. But how do I avoid this happening – turn from each end towards the middle perhaps. Or is there a better way?
        #350738
        norman valentine
          @normanvalentine78682
          You could place a sacrificial piece of wood or maybe metal behind it to support the edge.
          #350743
          Jon Gibbs
            @jongibbs59756
            I think those are the two ways – back up the piece with another piece of waste stock or cut from both sides to the middle.
            Jon
            #350762
            MichaelR
              @michaelr
              I used a piece of chip board as a backing when turning sections for my traction engine brake blocks in Tufnol. Mike.Tufnol
              #350969
              Ian S C
                @iansc
                The first gear I cut, using a single point fly cutter was a Paxolin (or similar) one, I placed the Paxolin between two 3/16" thick steel discs, and as there was room on the finished job (a water pump), I left the steel parts in place, twenty years on and it's still working ok.
                Ian S C
