Lister engines
Lister engines
Home Forums General Questions Lister engines
  • #349332
    Eric Cox
      @ericcox50497
      In ME 4584 there is an advert for an auction that includes a number of restored Lister engines.
      Does anyone know the going price of a restored Lister engine.
      #25931
      Eric Cox
        @ericcox50497
        #349335
          The common ones like a D are quite cheap, less than some sets of model castings couple of hundred should get you one ready to show.
          #349352
          martin perman 1
            @martinperman1
            Eric,
            I collect and restore Lister engines, as Jason says D's are cheap but prices are rising, for me to get you a good idea I would need the spec no and serial no as engines which have spec 11 to 13/14 can fetch in good order upwards of £200 to £300 pounds, un restored runners, spec no 20 and upwards £50 to £100 each. you then get type A, B F, G, H, J, K, L, M, N, P, Q, R and X if its an X the price will go off the scale as very rare, there is only a known couple in the UK. All the other types can go between £200 and £1500 – £2000 depending on condition.
            I've just come in for a cup of tea, I've spent the morning stripping a H type ready to repair and show at rallys this year.
            Can you copy advert as I dont get ME.
            Martin P
            #349389
            martin perman 1
              @martinperman1
              Eric,
              I've taken the liberty of down loading the engine list and I've put what I consider are good prices the engines may fetch, hope this helps.
              1924 5hp Lister ‘L’ £350 1928, Lister ‘L’ 6.5hp,£400 1926 Lister ‘A’, £250 -£300 1931 Lister ‘D’ £75and 3 other Lister (2 shaft drive) ‘D’s shaft drives £150, 1921 Lister ‘J’ £300, Crossley 1065 5.25 hp £400, 1912 Massey Harris 1.5 hp £500 – £600, 1915 Stovers 1hp £500-£700 Amoco water pump £200, Godwin water pump £50-£100, belt drive, engine wheels, paraffin dispenser, merry tiller with Honda engine, 12.5 KVA generator, electro frege 415 V motor, Bendle chaff cutter £50-£100.
              Martin P
              #349429
                I have several copies of Stationary Engine magazine from late last year and a Lister D in running condition seems to go for £150 – £160 on wheels.
                neil
                #349442
                martin perman 1
                  @martinperman1
                  Neil,
                  A set of four cast iron wheels can easily fetch £50 to £60 and are usually reflected in the engine price, SEM for sale prices are also usually on the high side. Depending on who wants it Auctions can raise the price. I have 10 lister D's and depending on what spec they were I've paid £50 for a runner and £200 for a Hamworthy pump set being driven by a D on a cast base.
                  Martin P
                  #349500
                    Posted by martin perman on 08/04/2018 19:32:56:
                    Neil,
                    Martin P
                    Blimey! I thought £150 was cheap!
                    My Suffolk lawnmower engine on a sled must be worth at least £5. But that's £5 more than I paid for it…
                    #349502
                    martin perman 1
                      @martinperman1
                      Depending on what model Suffolk engine they are starting to increase in price.
                      Martin P
