Given that you have wifi there and also mains power, get yourself a wifi smart switch like the Sonoff S20. You can then use it to turn a light on and off from anywhere in the world (or your house) to illuminate the door. You can then view the door through the camera, then turn the light back off.
I've got a smart switch in the workshop (actually a TP-Link) that is scheduled to turn off every night at 11pm, regardless of whether it was ever turned on manually. This means I can't accidentally leave my equipment turned on overnight. With these devices, you can program scheduled events from your smart phone.
The TP-Link model I've got (HS110) is a slightly snazzier version (than the basic smart switch), that reports back the power consumption and energy useage.
These wifi enabled devices are becoming much more affordable. You can now buy a range of devices for remote ("smart"
access and even make your own domestic alarm system, complete with cameras, sounders etc.
As ever, you need to be wary of buying mains gear directly from abroad. It almost looks as if the Itead (Sonoff) gear has proper safety approvals for Europe and they appear to be available from recognised UK outlets eg Amazon. However, some brands might present shock and fire risks, so there is a strong argument for sticking to reputable brands such as TP-Link if you want to play safe.
Murray
