phosphor bronze interference fit
Home › Forums › General Questions › phosphor bronze interference fit
  • #25626
    petro1head
      @petro1head
      #327068
      petro1head
        @petro1head
        I have been given a job to do from a pal of mine.
        He has a phosphor bronze casting with a steel pin in it. The holes for the pin have become worn and he wants me to make a couple of bushes, machine the casing and fit the bushes.
        What sort of interference fit should I go for?
        #327073
        Emgee
          @emgee
          If the casting is not subjected to heat when in use you could go for a shrink fit of the new bushes into the casting.
          The fit of the pin in the new bushes will be determined by the use, if they have to be removed during use then possibly just a sliding fit is required.
          Emgee
          #327081
          petro1head
            @petro1head
            Hi
            The pin is a sliding fit.
            Its the bush thats an interference fit. However what tollerance?
            #327097
              Rough rule of thumb is one thou interference per inch of diameter.
              Depends on how big the job is and how thick the casting is and what its application is though. If it is something delicate you might make it a neat sliding fit and Loctite the bushes in place. If it's a big lump of a thing, a thou of interference and pull the bush into position with a nut and bolt etc or heat the casting and expand it to drop the bushing in and let job shrink to fit. Beware of cracking old castings with too much interference or heating though.
              A few details on what the casting is would help.
              Edited By Hopper on 14/11/2017 11:49:32
              #327101
              Mick B1
                @mickb1
                Posted by Hopper on 14/11/2017 11:44:00:
                That would be my understanding too. A few degees taper on the first 5mm or so of the bush o/d would aid location. Many folk use a hydraulic press for fitting if available and if the parent part isn't too thin around the 'ole – you don't get the variables you do with heat, plus you can handle it straight away.
                #327104
                KWIL
                  @kwil
                  Make the bush a tight fit size and then leave the bush in freezer before fitting, should drop in, but do not hang around doing it
                  #327105
                  petro1head
                    @petro1head
                    Its a brush assembly for an electric traction motor off a train,
                    In the second photo you can see how the pin has warn into a repair that was done a few years ago.
                    The third photo is the pin which holds the spring in place and tensions it.
                    I was thinking about putting the bush in the freezer
                    Hope this helps
                    Edited By petro1head on 14/11/2017 12:38:15
                    #327117
                    duncan webster 1
                      @duncanwebster1
                      There is a useful table at
                      Not suggesting you need to work to these tolerances on bush and hole, but together they give the clearance/interference for different classes of fit.
                      Edited By duncan webster on 14/11/2017 13:53:16
                      #327118
                      Tony Pratt 1
                        @tonypratt1
                        I would use Loctite.
                        Tony
                        #327124
                        Tim Stevens
                          @timstevens64731
                          The 'right' fit will depend on the thickness of the bush, as well as other factors. I think that a plain bush with Loctite would do the job. If you go for an oilite bush, too much interference is likely to collapse the bush inwards – a fault which is difficult to cure as a reamer will not serve. And Loctite won't do for oilite as it fills in the spaces for the oil.
                          It appears that the whole assembly has been sand-blasted (or similar). This might reduce the life of the springs, unless the abrasive used was 'friendly' – ie rounded chips rather than sharp ones. So, tell your friend to keep a careful eye on this detail in service.
                          Regards, Tim
                          #327134
                          dave train
                            @davetrain79096
                            The springs are replaced
                            The bush OD is 20mm and the ID is 16mm
                            PS Thanks for the replies
                            Edited By dave train on 14/11/2017 15:03:47
                            #327145
                              A minimal shrink fit looks easy enough, as the housing and bush have, near as dammit is to swearing, the same expansion coefficient. So bush in the freezer and housing in the oven on low heat.
                              #327163
                              J Hancock
                                @jhancock95746
                                It seems as though an awful lot of up and down movement of the brushes may be taking place to cause
                                that much wear.
                                Is the commutator running true ?
                                #327164
                                dave train
                                  @davetrain79096
                                  Wrong forum
                                  Edited By dave train on 14/11/2017 17:25:06
                                  #327170
                                  dave train
                                    @davetrain79096
                                    Oh bugger
                                    Edited By dave train on 14/11/2017 17:25:37
                                    #327174
                                    petro1head
                                      @petro1head
                                      Question……..s
                                      Managed to snap a couple of drills, any idea why? [EDIT] Found this helpfull videp – https://www.youtube.com/watch?v=pAngKHIZgyA
                                      I bored out the bushes using drills and finished off with a 5/8 2 flute end mill which was fine however I was then asked to bore them out to 16mm so used one of the 3 flute mills that I normally use for alloy and it chattered and ended up creating a poor finish.
                                      So, as this is the first time I have worked with phospher bronze should the drill tips be at a different angle?
                                      Should I be using different end mills?
                                      #327179
                                      RRMBK
                                        @rrmbk
                                        Hi.
                                        I have just put a 2" od 1/8 wall 4 2 long Phosphor bronze bush into a cast iron cylinder. I machined the bush to 2 thou oversize. As my lathe turns a slight taper over this length I had 1 thou over at one end and 2 thou at the other.
                                        I put the bush in the freezer and heated the casting bore for 10 mins with a hair dryer. The bush slid in and very soon grabbed fast. It was slightly beyond where I wanted it at one end and I had to put some serious effort into the puller I made to shift it just 5 thou.
                                        What is important is that you get your location right first time. From the look of your application there seems to be no reason why you cant make the bushes "top hat " type so they will positively locate against the frame. However if you have the room to make the "top hat " why not make the bushes a dead fit and secure them in place with three screws into threaded holes at 120 degrees. It would then be an easy matter to replace the bushes at a future date when they wear.
                                        hope this is helpful
                                        kind regards
                                        BK
                                        #327180
                                        Speedy Builder5
                                          @speedybuilder5
                                          Petro1head's link for grinding drills would be useful for answering another forum question "Runout drilling 2mm hole" ?
                                          BobH
                                          #327182
                                          Anonymous
                                            Errr, you don't use drills to bore holes?
                                            Here are a few pointers:
                                            When drilling bronze it can "grab" the drill, like brass only worse. The general advice is to stone a flat on the cutting edge of the drill. That's never worked for me, so I use slow helix drills.
                                            Tooling for bronze needs to be sharp, sharp, sharp!
                                            Bronze doesn't like shallow depths of cut, especially if the tool isn't very sharp. The cutting edge seems to ride over the surface, until you add a little more cut, at which point the tool bites, and you end up with over, or under, size work. sad
                                            Bronze also has a tendency to close up slightly after machining. So if you ream a hole and then try the reamer by hand it won't go in without a lot of force, if at all.
                                            Using endmills as a "drill" does work, but you need a rigid setup to avoid chatter. Basically lock everything that isn't moving.
                                            I suspect that the bronze "closed up" on your drills and the resulting torque was enough to snap them, especially if you weren't using coolant.
                                            Edited By Andrew Johnston on 14/11/2017 17:47:35
                                            #327186
                                            petro1head
                                              @petro1head
                                              Maybe I have not given enought info.
                                              The bushes and made from a round bar of PB, the bar is machines using a lathe. I use drills to get close to where I want to be and finish off with an end mill, more for good finish.
                                              Tollerance for the pin in the bush is not tight so easy enough job.
                                              I often use an end mill to fish a hole off if I dont have a drill big enough. This is ok for me as I don't do any high presicion work
                                              Anyway we have gone off topic and maybe I would be better starting a new topic about working with Bronze?
                                              Edited By petro1head on 14/11/2017 18:27:29
                                              #327210
                                              Mick B1
                                                @mickb1
                                                Presumably we're talking about PB102? There are other grades that are sometimes called Phosphor Bronze, but PB102's probably the most definitive..
                                                It's true that tools need to be sharp with a good finish, otherwise you can get lots of tiny tears in a dull, abrasive outer surface. Top rake much like mild steel, say about 8 degrees. When turning, I've found a narrow plan trail angle helps too.
