High Grade Aluminium Supplies
Home › Forums › General Questions › High Grade Aluminium Supplies
  • This topic has 10 replies, 7 voices, and was last updated 2 May 2014 at 22:48 by Involute Curve.
  • #151173
    Involute Curve
      @involutecurve
      Looking for a little help I can get hold of thick plate in 7075 and 7020 in fact I have quite a bit, but I'm trying to source some 7075, 6mm plate and 1/2 in plate, however not large sizes probably buy 1m x 100mm couple of length of each I can get away with smaller lengths they are to machine 50×70 components from, no dims are critical just this sort of thickness's.
      any help would be much appreciated
      Shaun
      #23282
      Involute Curve
        @involutecurve
        7 series
        #151175
        Anonymous
          I use Metalfast for aluminium products, they will cut to size if required, or ask about offcuts.
          #151209
          David Senior
            @davidsenior29320
            I also use Metalfast (or ThyssenKrupp as they are now known) but have recently started using Shropshire Stainless & Aluminium http://www.ssaltd.net . Not sure whether they will deal without an account, but they are very keenly priced on sawn plate.
            Involute Curve
              @involutecurve
              I've used them both in the past and very good the are, but neither do 7075 or 2014 in 6mm or 1/4 plate.
              Another good supplier is the Aluminium wharehouse, but again they don't do the above.
              Bummer
              #151237
              Speedy Builder5
                @speedybuilder5
                Have you tried these? I used them in the distant past.
                http://www.smithmetal.com/
                BobH
                #151239
                  Shaun,
                  One more possible source, here
                  Anonymous
                    Posted by Involute Curve on 02/05/2014 07:55:44:
                    Odd, Metalfast list 2014 in 6mm and 1/4" and 7075 in 6mm in their stocklist. If they hadn't I wouldn't have wasted my time posting. Maybe they're telling porkies?
                    #151275
                    M0BND
                      @m0bnd
                      Posted by Involute Curve on 01/05/2014 12:49:21:
                      Shaun
                      Does this come under the description of 'shate'? http://www.raaltd.com/alu_plate.htm
                      Andy.
                      Edited By M0BND on 02/05/2014 20:05:38
                      #151277
                      The Merry Miller
                        @themerrymiller
                        As a matter of interest for all concerned:
                        Up to 6mm (excluding foil or shim) is designated "Sheet"
                        Above 6mm is designated "Plate"
                        Len.P
                        #151283
                        Involute Curve
                          @involutecurve
                          Posted by Andrew Johnston on 02/05/2014 10:25:22:
                          Perhaps the web site need updating, when I rang them and Smiths 10mm was the best they could do in the sizes I wanted, anyhow I've sorted it for now, I sliced a couple of bits off a lump of 3" plate I have, it will get me away until I get supply.
