Machine plate grouting (most common method)
Home › Forums › General Questions › Machine plate grouting (most common method)
  • This topic has 15 replies, 8 voices, and was last updated 1 May 2014 at 22:48 by Marcus Bowman.
  • #23279
    Steve Wan
      @stevewan33894
      #151073
      Steve Wan
        @stevewan33894
        Hi guys
        Has anyone here try concrete grouting over a metal base plate to increase the weight of the machine? I like to add more weight on the power hacksaw base plate. I need to know what's the most common practise used. Or simply using extended bolts and pour the mortar over the inverted base plate? Appreciates any tips and guides-Steve Wan
        #151074
          Not heard of this before. Seems a little awkward to reverse. How about casting an entirely seperate lump of concrete to bolt the machine to.
          #151078
          Steve Wan
            @stevewan33894
            Hi Bazyle, I'm open to any option. Your way is good for servicing in the future to take the heavy load away when not in use, easy to carry off the weight-thanks!
            #151079
            JohnF
              @johnf59703
              Hi Steve,
              Have a look on the http://www.lathes.co.uk web site at Peatol and Taig lathes, they use an aluminium extrusion filled with concrete as their machine base.
              Steve Wan
                @stevewan33894
                Hi John, unable to see the Taig cast. Perhaps, I find a baking tray to cast the slab. Once dried, I invert it and bolt to the base of the power saw. As the tray has a curvy edges, spray a texture paint. One may take it as part of cast iron.
                #151088
                  Steve,
                  It might be easier to bolt the machine down to a paving slab.
                  … what "footprint" is the base of the machine ?
                  Ian S C
                    @iansc
                    Is your power hacksaw a bench mounted type, or is it mounted on legs? If on legs, a weight at each end, one for each pair of legs, a bolt cast into the concrete for each leg, sit the saw over the bolts, put on a nut. I'd make the concrete about 50 mm / 2" thick, the size would be dependant on the size of the saw. Ian S C
                    #151095
                    Steve Wan
                      @stevewan33894
                      Hi Micheal, I'm trying to figure out the best footprint Hi Ian, nice to hear from you again. Yes, it would be mounted on 4 legs. I may cast the concrete on a wooden plywood tray with a thick base, supported by 4 legs. The motor is screwed underneath which in turn pressure the pulley belt. The power hacksaw unit is then bolted above the tray.
                      #151103
                        Posted by Steve Wan on 30/04/2014 11:16:19:
                        Sorry Steve, I presumed you were talking about the machine in your photo album
                        If you are still at the design stage, then:
                        The best footprint would be one that fits nicely on whatever heavy paving slab you can acquire.
                        … Get the slab first, drill some holes; then make the mounting feet to fit.
                        Ian S C
                          @iansc
                          Steve, I hadn't until now looked at your photo, I see that it is basically the same as the one that is evolving here, I had not thought of the top rail with the weight, Looks like a good idea, that will go into the design ideas department. What I would do is Fit wheels at the rear, under the motor, arranged so that they come in contact with the floor when the front end is lifted. Might be a bit difficult on the cast (?) legs on your machine. I suspect my saw will have wooden legs, the main body of it will be the bit of 4" x 2" channel steel that was the basis of my first saw.
                          Ian S C
                          #151183
                          Jon Gibbs
                            @jongibbs59756
                            Another way often used with wood lathes is to add a ballast box and fill with kiln dried sand – either bagged or not.
                            It will also do a good job of damping vibrations and isn't as much work as casting concrete by any means.
                            Hope this helps
                            Jon
                            #151190
                            John McNamara
                              @johnmcnamara74883
                              Hi Steve Wan
                              I am not sure what your are trying to achieve, Is it to reduce vibration? Or is it to stop the machine walking along the floor when it operates? A hacksaw is not a high precision machine.
                              A lot of machine commercial builders fill their steel machine castings with Epoxy composite material
                              Usually gravel/Silica sand/epoxy as a damping medium. Some do away with the steel and make entire frame castings from the epoxy material, Hermle in Germany use it for most of their machines For example: **LINK**.
                              The use it to reduce vibration important when you are working to microns.
                              Steve Wan
                                @stevewan33894
                                Hi guys
                                Thanks so much for the feedbacks and concerns.
                                It's at the raw stage now. The concrete fill is to dampen the vibration only. I would prefer using concrete fill as I'm familiar with. The mix would include loose fibre-glass threads and wire mesh to hold the structure intact from cracks. Basically, I will make an inch deep with a well around the aluminium block where the saw is attached.
                                If anyone here is keen to follow through the process, please keep my email: [email protected]
                                I shall post photos as I get along, it may take time as I have many other jobs. The whole process is made by small scale Sherline mill /lathe and plenty of hand work such as sawing/filing and sanding.
                                Steve Wan
                                #151214
                                  Posted by Steve Wan on 01/05/2014 18:24:59:
                                  Steve,
                                  I obviously mis-understood your original question … I thought you just wanted to add mass, but it's now obvious that you want damping. In that case; as well as looking at the "Epoxy Granite" materials mentioned by John, it might be worth you reading-up on "constrained-layer damping"… This can be very easily achieved by building a bolted or bonded sandwich of metal plates and [for example] Tufnol or MDF.
                                  Marcus Bowman
                                    @marcusbowman28936
                                    There is a large, long-running thread about epoxy/concrete fills here:
                                    http://www.cnczone.com/forums/epoxy-granite/
                                    Marcus
