Miscellaneous information and materials wanted
Home › Forums › General Questions › Miscellaneous information and materials wanted
  • #69986
    David Clark 13
      @davidclark13
      Hi There
      A few questions for you.
      Can anyone tell me when the Chuck cartoons started in Model Engineer, the year would do?
      Could someone scan and email me the Clarkson Autolock Handbook, at least the speeds and feeds charts but preferably all of it?
      Has anyone got a pair of rear wheel rims for a Minnie traction engine they could sell me cheap.
      They don’t have to be perfect, undersize or part machined considered. Ideally one of them not machined on the inside. I need them for a turning article.
      #21878
      David Clark 13
        @davidclark13
        #69987
        David Clark 13
          @davidclark13
          Hi There
          The main photo top left of the home page of this site is showing a broken link on my laptop but is fine on my main PC.
          Does anyone else have a missing photo and if so, what browser are you using.
          regards David
          #69988
          David Clark 13
            @davidclark13
            Hi There
            The Zeus Data book has a page showing how to work out the dimensions for pitching out holes on PCDs.
            Does anyone know of this chart or similar in another book?
            I would like to use this table/method in an article but obviously can’t just copy the Zeus book.
            The data must be constant but I need to confirm that.
            regards David
            #69989
            David Clark 13
              @davidclark13
              Hi There
              Many years ago, I had a table of speeds for a machine tool.
              What it showed was the relationship from one speed to the next as the speeds stepped up.
              It ended up as a saw tooth graph across the chart where you could plot the cutting speed and see how linear the speed steps were.
              Does a machine designer or anyone else have an example of this type of chart?
              It would save me figuring it out from memory.
              regards David
              Edited By David Clark 1 on 09/06/2011 05:14:53
              #69990
              David Clark 13
                @davidclark13
                Hi there
                Has anyone used the type of edge finder that has a point, I am not talking about the sticky pin version, I am talking the parallel one with a point on it.
                I assume it is for finding the centre of holes but am not sure how it works.
                I suppose you could drop it into the hole and wobble of the edges of the hole in the X axis to find the centre and then wobble of the front and back in the Y axis to give the true centre?
                regards David
                #69991
                John McNamara
                  @johnmcnamara74883
                  Hi David
                  I had the same problem with my Mill
                  A shizuoka VHRG It has had its thirtieth birthday and still going strong!
                  The link below to an excel spreadsheet, creates a chart with the steps you mention; you can customise it to fit your various machines and get the exact numbers for each machine you work with. Make a separate copy for each machine.
                  If you have any trouble I would be pleased to help.
                  Cheers
                  John McNamara
                  Edited By John McNamara on 09/06/2011 05:53:38
                  #69992
                  Styx
                    @styx
                    Hi David,
                    Here is a link to a free PCD calculator which I find very useful and use all the time at work. It also gives you data for chain drilling holes which would be useful for the portable engine.
                    Hope this helps.
                    Steve….
                    #69994
                    Terryd
                      @terryd72465
                      Hi David,
                      Here’s a quote from the above web page mentioned by Steve which may be useful:
                      “In MEW (Model Engineers Workshop) issue 100 Harold Hall described the formulas for calculating Pitch Circle Diameters…………..”
                      Hope this helps
                      Terry
                      #70017
                      Nicholas Farr
                        @nicholasfarr14254
                        Hi David, in an index I have there was a posting in Smoke Rings Vol122 3052 1960 page 2. Vulcan. Meet Chuck (The Muddle Engineer). Then in issue 3053 on page 34; Humorous, Chuck, The Muddle Engineer. Aspin. Exhibitions Models compared to his own.
                        Don’t know if this is what you are looking for. I don’t have any 1960’s issues so cannot view them myself, but maybe someone else can.
                        Regards Nick.
                        #70019
                        David Clark 13
                          @davidclark13
                          Hi Nick
                          That is fine.
                          I thought I remembered them from that far back.
                          regards david
                          #70039
                          Ian S C
                            @iansc
                            There are about 335 entries from B. Terry Aspin as Chuck the Muddle Engineer, from 1960, vol 122, trying to start the motor mower, to2006, vol197, foundry work. A total of 46 years. Ian S C
                            #70153
                            1
                              @1
                              Hi David
                              Have you had a response to your question 7 of this thread yet? I was given a set of edge finders amongst which is one of the pointed type of which you speak and I haven’t a clue how it is used either.
                              Jim
                              #70158
                              ady
                                @ady
                                Most of this stuff disappears.
                                Anyone remember Reg Prescott?
                                One of the most skilful British engineers in history.
                                You may have a seisure when you view his stuff, nowadays it’s actually against the law to have a really good laff.
                                Edited By ady on 12/06/2011 02:51:16
                                #70161
                                David Clark 13
                                  @davidclark13
                                  Hi Jim
                                  No, but one arrived yesterday.
                                  I will have a play in the week.
                                  I have an idea that I can use it in a different way for the lathe which is why I bought it.
                                  regards David
                                  #70164
                                  chris stephens
                                    @chrisstephens63393
                                    Hi David,
                                    In the excellent(?) series of videos from MIT, the demonstrator shows the use of such a tool. According to him you put the pointy bit in a hole and align said hole by judicious use of a finger nail over the misaligned sides.
                                    chriStephens
                                    #70167
                                    David Clark 13
                                      @davidclark13
                                      Hi Chris
                                      Do you have a link?
                                      regards david
                                      #70171
                                        About 26 mins into video 1
                                        J
                                        #70173
                                        1
                                          @1
                                          Oh, that simple! The video didn’t play but I have had a deal of difficulty with MIT vids in the past and no matter because the description given here by Chris Stevens and in the narrative on the MIT site shed all the light necessary.
                                          Must remember the KISS principle in future.
                                          Jim
                                          #70174
                                          chris stephens
                                            @chrisstephens63393
                                            What he said! Saved me trying to find it by looking at several hours worth of videos.
                                            chriStephens
                                            #70177
                                            chris stephens
                                              @chrisstephens63393
                                              Hi Jim,
                                              Once you have been let in on the secret most things are simple, with the possible exception of affairs of the heart and an appreciation of modern art.
                                              chriStephens
                                              #70179
                                              Steve Garnett
                                                @stevegarnett62550
                                                Posted by David Clark 1 on 09/06/2011 05:02:09:
                                                regards David
                                                Seems to work on all three browsers here just fine – that’s Firefox, Internet Exploder, and Google Chrome. What browser do you have that it doesn’t work on?
