End float on ML7-R leadscrew
Home Forums General Questions End float on ML7-R leadscrew
  • #66479
    The Merry Miller
      @themerrymiller
      Morning everybody,
      Prior to starting some screwcutting yesterday I noticed that the leadscrew of the above lathe, which I have not had for very long, had what I thought was excessive end float.
      Does anybody know what the min and max leadscrew end float should be on the ML7-R-B.
      (It has the Myford gearbox fitted.)
      #21836
      The Merry Miller
        @themerrymiller
        #66540
        The Merry Miller
          @themerrymiller
          Thanks for the info about the thrust bearing kit Gray.
          Got straight on to Kirk at Hemingway and ordered the kit (£26.60).
          Should have it by the weekend.
          #66657
          KWIL
            @kwil
            I have fitted these needle roller thrust bearings to both my Super 7s, adjust for minmum end float without binding. They work (and continue to work) very nicely. You can forget end float. Do not forget to dowel pin the bracket if not already done. This keeps it nice and square.
            #66659
            The Merry Miller
              @themerrymiller
              Thanks for your help folks, the kit arrived yesterday (very good service from Hemingway)
              Hopefully do the mod next week.
