Alibre image tracing
Home › Forums › CAD – Technical drawing & design › Alibre image tracing
  • #643441
    Ady1
      @ady1
      I finally got this to work by apparently clicking "legacy display" to disable it (didn't work anyway), then unclicking legacy to make it ok (yes I know, weird)
      in file-system options-display-general
      #21418
      Ady1
        @ady1
        insert a picture, scale it, then start drawing
        #643444
        Ady1
          @ady1
          So you scale the pictures of the different views in their respective planes then start to draw the bits you want
          I had put my Drummond dwg on hold because it would take lots of work to run about and measure it all up
          if you can take your own pictures then you only need one measurement and the rest will fall into place because you've got all the aspects you need and you only need to scale your jpegs
          Only got this fixed an hour ago, has never worked for me previously, its probbly ok for most folk
          Edited By Ady1 on 01/05/2023 18:44:37
          #643447
            It's a useful tool particularly if you want to draw a cast part that has curves and angles, can be done with photos or scans of drawings where you usually only get the machined parts dimensioned.
            #643448
            Fulmen
              @fulmen
              Is that from an Mg42?
              #643454
              Ady1
                @ady1
                My current Alibre homework
                Edited By Ady1 on 01/05/2023 19:33:18
                #643459
                blowlamp
                  @blowlamp
                  Posted by Ady1 on 01/05/2023 19:31:35:
                  Nicely done, Ady1. yes
                  #643460
                  Fulmen
                    @fulmen
                    Very nice work. I've done a few such builds over the years, it's a lot of work.
                    My first 3D work was the US M2 using the primitive 3D functions in Autocad back in the early 2000's.
                    #643484
                    Ady1
                      @ady1
                      Thanks guys.
