BA Allen Keys
BA Allen Keys
Home › Forums › Workshop Tools and Tooling › BA Allen Keys
  • #20501
    Bob Unitt 1
      @bobunitt1
      Looking for BA Allen Keys
      #571694
      Bob Unitt 1
        @bobunitt1
        Does anyone know where I can get BA Allen Keys, preferably in a set ? I've tried the usual suppliers, but no luck sad
        #571695
        DMR
          @dmr
          BA was never metric to my knowledge. You need an imperial inches set.
          #571696
          Clive Brown 1
            @clivebrown1
            AFAIK they don't exist. All the socket head BA fasteners I've ever used have fractional imperial sockets.
            #571697
              Should not be a problem getting 2, 2.4 and 4mm for the common even numbered BA cap heads which are 6, 4 and 2BA, Someone Like Model Fixings have key, tee wrenches and ball ended drivers in those sizes
              That is what I use and they all fit, if not go looking for 5/64, 3/32 and 5/32" again not too hard to find as are 0.9mm (0.035inch) and 1.27mm (0.050inch) which fit BA grub screws. Same supplier does them too.
              Edited By JasonB on 17/11/2021 13:18:16
              #571698
              Mark Rand
                @markrand96270
                Use normal imperial Allen keys. There are no separate BA Allen keys
                #571706
                Nigel Bennett
                  @nigelbennett69913
                  Machine Mart do a set of miniature Allen keys Product Code 040215196 which are small metric and Imperial.
                  #571720
                  Bob Unitt 1
                    @bobunitt1
                    Thanks for all the replies. The reason I asked was because I have a set of 4 BA capscrews which neither my metric nor my imperial allen keys fit, but I have an allen key supplied as 4 BA by a model engineering firm which fits them perfectly.
                    #571724
                      Sounds like you have some odd 4BA screws if imperial keys won't fit. This is a 4BA with a nominal 3/32" key which fits fine. Details of key sizes can be found here and as I said the metric ones fit too.
                      Edited By JasonB on 17/11/2021 16:06:14
                      #571725
                      bernard towers
                        @bernardtowers37738
                        ITEMS , Mail order do all the keys and they are good quality.
                        #571740
                        Tim Stevens
                          @timstevens64731
                          It is one of the better ideas among the dozens of fastener shapes and sizes, that Whitworth, BSF, UNC, UNF, UNEF and others all take the standard Inch sizes of Allen key.
                          And beware – some supplies of BSF from the left-hand edge of the Pacific come with socket heads for metric Allen keys.
                          Cheers, Tim
                          #572040
                          Brian Morehen
                            @brianmorehen85290
                            have used BA allen screws for years down to 8 BA . AF allen keys have always been correct ,I believe these also been in use be fore Metric appeared
                            regards Bee,m
                            #572049
                            V8Eng
                              @v8eng
                              Some time ago bought a metric/imperial set on offer from Screwfix in a handy flip case.
                              They seem to fit anything (within size range) that I’ve tried so far and appear tough.
                              https://www.screwfix.com/p/magnusson-metric-imperial-hex-key-set-30-pieces/3305v
                              Screwfix
                              Edited By V8Eng on 19/11/2021 21:24:13
                              #572062
                              ega
                                @ega
                                By way of addition to Jason's link, 8BA set screws take a 0.035" key. For the 1/16" sizes and above I identify them by 1/64"s, so that, eg, a 5/32" is a number 10 in my system.
                                The small L-shaped keys can be quite flexible and when more torque is required I use the 1/4" AF shank bits in a holder; these seem to be available down to 0.050".
