What O-ring is this?
Home Forums Workshop Tools and Tooling What O-ring is this?
Viewing 25 posts - 1 through 25 (of 33 total)
  • #570954
    Gary Wooding
      @garywooding25363
      My ancient Sievert blow torch gave me a fright today – it burst into flames as I was using it. I was able to blow them out and I wasn't burned, but it was rather scary. The flames originated around the valve, so I dismantled the handle and reckon I need a new o-ring. I've got a box of o-rings, but none of them fit.
      Does anybody know which one I need? The photos show the torch handle and valve with the o-ring separated. Sorry about the focus, I blame it on my phone.
      #20495
      Gary Wooding
        @garywooding25363
        #570960
        J Hancock
          @jhancock95746
          Looks like the 'gas' has swollen the O -Ring , whatever size you choose , do make sure it is compatible for
          use with the gas you are using.
          #570962
          Jouke van der Veen
            @joukevanderveen72935
            It seems to be a “square”-ring, not an “o”-ring.
            Why this shape is applied, I do not know.
            Does this ring constantly see gas, also when you do not use the equipment?
            #570965
            Gary Wooding
              @garywooding25363
              It's actually rather difficult to see, but it looks like the ring only sees the gas when the valve is open.
              #570970
              Jeff Dayman
                @jeffdayman43397
                I'd ask a Sievert dealer first about a replacement, but if they don't have them, o-ring suppliers will. If it is actually intended as a square section o-ring, they are available, see link below.
                https://www.theoringstore.com/store/index.php?main_page=index&cPath=367_2203
                However it may have started out as a normal round section ring and has just compression set to the square groove shape, In that case, I suggest going to an o-ring firm or industrial supply, and test fit a few to get a good fit. If that isn't possible you can buy an assortment of o-rings quite cheap from Ama Zone or E you know and find one. If you get one rated for hydrocarbon / oil service it will be OK with gas. Depending on how hot it gets in the torch, you may want a high heat one. Good luck.
                #570973
                  Probably worth grabbing this catalogue whilst it is still available: **LINK**
                  https://sievert.se/wp-content/uploads/2016/11/Sievert-Catalogue-UK-2016_web.pdf
                  Several O-rings identified therein.
                  Oldiron
                    @oldiron
                    Sievert probably still stock spares for that gun Gary.
                    Are we banned from saying AMAZON & EBAY. ???????
                    As far as I recall we are allowed to mention these two huge companies in this forum. Why do ppl faff around when it is easier to type the actual name than think of a pseudonim ?
                    regards
                    #571018
                    Gary Wooding
                      @garywooding25363
                      Neither eBay nor Amazon helped much, and TheOringStore are outrageously expensive – it's cheaper to replace the torch. A semi-retired guy at Rothemberger (Sievert) thinks he may have one in a dusty drawer somewhere. He'll let me know next week. Maybe I'll get lucky.
                      #571040
                      Les Jones 1
                        @lesjones1
                        As you have not given any dimensions of your O ring I estimate from your picture that it is about 6mm ID and about 2mm cross section.
                        If this is a correct estimate then this is one possible source.
                        Les.
                        #571046
                        Phil H1
                          @philh196021
                          Gary,
                          I am really interested in the answer because I think I have the same or at least a similar torch. Does yours have the economiser trigger? Mine too is ancient but is still an excellent torch. I haven't used mine since the mid 1980s and even then it was ancient.
                          Phil H
                          #571061
                          bernard towers
                            @bernardtowers37738
                            Bearing companies, hydraulic companies and pneumatic companies all use ‘o’ rings drop into one with your torch you’ll be surprised how helpful people can be when you are actually in front of them.
                            #571089
                            Gary Wooding
                              @garywooding25363
                              Les,
                              It actually measures 6.2×2.5, do you suppose a 6×2 would do the job?
                              #571097
                              Nicholas Farr
                                @nicholasfarr14254
                                Hi Gary, looks like it is an imperial size of 1/4" x 3/32" and by the looks of the age of your torch is very likely. LPG will leak out of the smallest gaps it can find, so I would try and find one that is much closer to the one you want to replace.
                                Regards Nick.
                                #571102
                                Les Jones 1
                                  @lesjones1
                                  This is one source from ebay. (But you will probably find more as I only spent a few minutes searching.)
                                  Nitrile seems to be a good choice for propane or butane.
                                  Les
                                  #571113
                                  Circlip
                                    @circlip
                                    Not forced to be a "Standard". Only place to get o-rings for carb on my bike was from carb spares supplier. Similar problem with the one the water governor on boiler.
                                    Regards Ian.
                                    Edited By Circlip on 13/11/2021 10:55:23
                                    #571117
                                    Gary Wooding
                                      @garywooding25363
                                      Thanks Les,
                                      The link you supplied looks promising, I'll give it a try.
                                      #571251
                                      Brian Morehen
                                        @brianmorehen85290
                                        Morning Garry , Took my Torch to pieces this morning am certain that this is round at the top mine is quite visible , The next question is this a Metric Size or Imperial Size as both are available.
                                        Regards Bee.m
                                        #571265
                                        Gary Wooding
                                          @garywooding25363
                                          Hi Brian,
                                          Nick's observations that my measured dimensions (6.2mm x 2.4mm) are very close to 1/4"x3/32" (6.35mmx2.38mm), and I couldn't find any metric sizes that were closer leads me to think they are Imperial. That's what I'm going for.
                                          #573328
                                          Gary Wooding
                                            @garywooding25363
                                            I opted for the 1/4"x3/32" size (had to buy 5) but it turned out to be a mite too big – the valve actually went in, but was far too tight. I probable something closer to 1/4"x1/16" will be OK.
                                            #573347
                                            duncan webster 1
                                              @duncanwebster1
                                              removed
                                              Edited By duncan webster on 28/11/2021 16:42:04
                                              #573358
                                              Nicholas Farr
                                                @nicholasfarr14254
                                                Hi Gary, 1/16" is a fair bit smaller than the 2.5mm you mentioned, so maybe 5/64" might be closer, perhaps This one might be better. Something went wrong, try This one
                                                Regards Nick.
                                                Edited By Nicholas Farr on 28/11/2021 18:34:24
                                                #573360
                                                  I’m not sure why anyone would even expect O rings on a Sivert torch would be anything other than metric.
                                                  Edited By not done it yet on 28/11/2021 18:50:21
                                                  #573395
                                                    Gary,
                                                    They may, of course, have revised the design over time … but this page from Cousins looks useful:
                                                    https://www.cousinsuk.com/product/handle-replacement-parts?code=B0123
                                                    martin haysom
                                                      @martinhaysom48469
                                                      Posted by Gary Wooding on 28/11/2021 14:31:08:
                                                      sometime the ring needs some lube
