Posted by XD 351 on 03/11/2017 07:44:20:
Did you try arc eurotrade ? They sell genuine sieg stuff that will fit your lathe and comes from one of the few good factories in china . I suspect you will have to make an adapter for a burnerd to fit a mini lathe .
Edited By XD 351 on 03/11/2017 07:46:37
Thanks for your kind comments. I would just like to clarify please, which I hope no one will mind…
The Chinese lathe chucks we sell are purchased through SIEG. If we have a problem, we sort it out with SIEG. In turn, they sort it out with the manufacturer. Having said this, there was a batch we had re-called, and this was posted on this forum at the time. Other then that, we get the odd faulty chuck, or a return where the customer is not happy with the chuck, even though the chuck is fine – no better or worse than the average Chinese chuck.
Having said the above, most Chinese chucks are fit for the purpose they are made for, provided they are procured through the right channels. The Zither chucks from India are better than the general Chinese ones, but you will need a plain backplate, to be turned on your mini-lathe for the register, then drilled and tapped by you to make the chuck fit. Again, one has to be careful without making presumptions that all Indian chucks are good. SHARP – Indian chucks from Chronos are also good. In all such cases, a backplate will need to be used.
Ketan at ARC.
