Old Railway Line
Old Railway Line
Home Forums Workshop Tools and Tooling Old Railway Line
  • #308430
    Nick_G
      @nick_g
      Great video of using what appears to be a section of old railway line. (looks very nice quality stuff to machine)
      #18590
      Nick_G
        @nick_g
        #308434
        Muzzer
          @muzzer
          Rail steel seems to be reasonably high carbon (0.4 – 0.8% or so), so can be hardened after machining.
          That one's looks a bit chunky in section to me to be made from railway line but making anvils from line seems to be quite a popular activity.
          Murray
          #308440
          Paul Lousick
            @paullousick59116
            The "chunky" rail is probably used on mobile cranes not locomotives.
            Paul.
            #308444
              That's quite the milling machine he has there. Expect it to take longer on your SX2 at home.
              #308447
              Ian S C
                @iansc
                Here's another railway related anvil, made from the square head of a 1" bolt.
                Ian S C
                Anvil , hammers, and a pair of Footprints
                #308495
                larry Phelan
                  @larryphelan54019
                  Can,t see too many guys making one of these,not in our shops,anyway.
                  Seems a lot of work to put in to produce something so useless,just nice to look at.
                  As an aside,that is one big,big machine!
                  #308506
                  Peter Sansom
                    @petersansom44767
                    Definitely crane rail. Used to use a similar profile for overhead cranes in a steelworks where I worked many years ago.
                    Peter
                    #308507
                    Rainbows
                      @rainbows
                      Likely of more use to the average engineer. The dude must just have a bunch of rail spare. I bet that vice will last a life time.
                      #308509
                      larry Phelan
                        @larryphelan54019
                        Yes,I can see that vice be a bit more useful.
                        #308518
                        mark costello 1
                          @markcostello1
                          Excellent skills, excellent machine, with an all angle table. Excuse Me while I go drool over the sink.
                          #308519
                          vintagengineer
                            @vintagengineer
                            Train railway steel is incredibly hard especially the top were the train runs. Even a disc cutter has trouble cutting it. I assume this has been annealed?
                            #308521
                            Anonymous
                              Posted by Hopper on 24/07/2017 01:06:11:
                              That's quite the milling machine he has…………..
                              Looks more like a horizontal borer?
                              #308522
                              larry Phelan
                                @larryphelan54019
                                Never knew there was such a thing as an angled table. Dont think I,d have room for that. Perhaps if I knocked out the end wall and moved a few things around and ——————————————————— Well,I can dream,can,t I?
                                Looks like he owns that Gaff and can afford to play around.
                                #308523
                                  Andrew's right. Looks very like this horizontal boring / facing machine, drool…
                                  #308541
                                  larry Phelan
                                    @larryphelan54019
                                    That,my friends,is what we should be aiming for. ! Forget your mini mills and your 3 1/2" lathes,this is the way to go!
                                    No more fooling around with "light" cuts,just get stuck in there and chop lumps off,right away.
                                    So,let us join together and knock out our end walls,side walls,back walls or whatever,never mind SWMBO. or the cost of running such equipment,it,s all in a good cause !
                                    Seems to me that this guy is on the wrong site!
                                    Now,where did I put that lump of 24"X 12" X 6" that I want to work on?,must be somewhere,perhaps behind the 4 High Mill?
                                    #308752
                                    mechman48
                                      @mechman48
                                      Nice job; but did he make it in works time, or in his own time with boss's permission to use machine?
                                      George
                                      #308754
                                      larry Phelan
                                        @larryphelan54019
                                        My guess is that he owns the joint,simple as that !
                                        Or else,he has a very understanding foreman,not like the ones I remember .smile d
                                        #309283
                                        Geoff Theasby
                                          @geofftheasby
                                          A similar anvil was on Chesterfield Market on Thursday. The foot was left as it came, so it was clearly a piece of heavy duty steel rail.
                                          Geoff
