Bench top mill
Bench top mill
Home Forums Workshop Tools and Tooling Bench top mill
  • #305270
    sean logie
      @seanlogie69385
      The title should read bench top mill?.
      I’ve decided I need to get myself a mill . Space is tight so a decent bench top would have to be my choice ,budget is tight absolute max of ?750 what would you recommend guys . The heaviest usage would be to make some extra QC tool holders .Been looking at a used Sieg x3 with loads of tooling.
      Sean
      Edited By sean logie on 03/07/2017 07:40:24
      Edited By sean logie on 03/07/2017 07:40:54
      Edited By sean logie on 03/07/2017 07:42:03
      #18569
      sean logie
        @seanlogie69385
        #305281
          Weelll, I would say a good Centec. But I would – as I like mine.
          Both horizontal and vertical options in one package. Mind you it will need to be a robust bench.
          Riser blocks are available on occasion, power feed is an option – good but expensive – and no silly DC motor and electronic motor control boards to go wrong.
          #305299
          sean logie
            @seanlogie69385
            I’ve been keeping an eye on a centec mill but it’s only in horizontal configuration so that would mean I’d have to source a vertical head for it which would prove costly . Building a stout bench not a problem .
            Sean
            #305327
              Vertical heads on epay often go well over 300 squid and have made over 600 – rather more than the rest of the machine!
              2 and 2A are cheaper and would definitly benefit from a riser block. 2B versions are more popular and fewer on offer.
              #305331
                If the X3 has been looked after and there is a lot of tooling it does not sound a bad buy.
                My X3 is going strong after just over 10years use, no electrical issues with the DC motor just a couple of £5 belts in that time and it gets used a lot and also for quite large items as they have a bigger work envelope than a Centec. X3 is also plug and play, no Inverter to eat into the overall budget to get the 3-phase machine to work
                Edited By JasonB on 03/07/2017 11:44:03
                #305346
                sean logie
                  @seanlogie69385
                  Hi Jason , the x3 has a lot of tooling . There are some going for 600 and no tooling.
                  Sean
                  #305352
                  Robbo
                    @robbo
                    Sean
                    I have only had one of the smaller Sieg mills, but it was good. If offered an X3 with tooling I would grab it, even though the X3 is now superceded I am sure spares will be available in the event they are needed.
                    Edited By Robbo on 03/07/2017 13:42:51
                    #305366
                    Stephen Benson
                      @stephenbenson75261
                      Space is so limited in my tiny indoor workshop that my bench has to be clear, have a lathe or a mill on it paid about £700 for the mill but will not lose much if I wanted to sell it
                      #305374
                        I would be happy with an X3 in good condition and lots of tooling if you have the space. You can do a lot on a lathe with a decent chuck, a tailstock chuck and a few HSS tools. With a mill you need different gadgets for every job!
                        sean logie
                          @seanlogie69385
                          Mills been sold dam!!!!!
                          Anyone have any ideas on the best place to search for a good used mill .
                          Sean
                          #305557
                          sean logie
                            @seanlogie69385
                            Anyone use Apex auctions?. They have this up for auction https://www.apexauctions.co.uk/auction/search?query=Bridgeport%20Milling%20machine&tree=
                            Was toying with the idea of sticking a bid on it ?
                            Sean
                            Edited By sean logie on 04/07/2017 19:18:31
                            #305585
                            Robbo
                              @robbo
                              Posted by sean logie on 04/07/2017 19:18:08:
                              Sean
                              Thought you said space was limited and you wanted a bench top machine?
                              Don't forget auctioneer's fees and VAT and cost of transport = load of dosh.
                              #305607
                              sean logie
                                @seanlogie69385
                                Struggling to find a decent benchtop mill . For the budget I’ve set .
                                Sean
                                #305660
                                sean logie
                                  @seanlogie69385
                                  Anyone know of a warehouse or shop that sells the like of what I’m looking in Scotland or the north of England . Prepared to travel for the right machine .
                                  Sean
                                  #305668
                                  Robbo
                                    @robbo
                                    You could try Barry at Bede tools and Machinery in Newcastle upon Tyne – [email protected]  tel 01914286575
                                    Edited By Robbo on 05/07/2017 14:05:09
                                    #305796
                                    Robbo
                                      @robbo
                                      Another approach is to put a Wanted ad on here :- **LINK**
                                      #305803
                                      Henry Artist
                                        @henryartist43508
                                        I have a Sieg SX1LP which I purchased from ArcEuroTrade. It is sufficient for my modest needs as I only build small steam engine models as a hobby.
                                        #305990
                                        sean logie
                                          @seanlogie69385
                                          Thanks everyone for the input… going to see the centec2 this afternoon and make an offer .it’s been sitting outside since the turn of the year so I reckon it’ll bee goosed.
                                          Sean
                                          Edited By sean logie on 07/07/2017 13:12:13
                                          #306051
                                          sean logie
                                            @seanlogie69385
                                            Well.. I’m now the proud owner of a Centec2 horizontal mill . Mill is already stripped down bar the arbour (haven’t figured out how that comes apart . The mill has had very little use I can still see the original grind marks on the ways ,all the leadscrews are like new . The spindle bearings feel good but I’m going to replace them anyways . It needs a motor if anyone knows of one let me know please. All in all I’m delighted ,it took nearly 9months 😁 so well worth the waiting and a bargain to boot 😉.
                                            Sean
                                            #306065
                                            sean logie
                                              @seanlogie69385
                                              Have now added a couple of photos in my albums .
                                              Sean
                                              #306139
                                              george356
                                                @george356
                                                Posted by sean logie on 05/07/2017 13:13:34:
                                                Anyone know of a warehouse or shop that sells the like of what I'm looking in Scotland or the north of England . Prepared to travel for the right machine .
                                                Sean
                                                Try http://www.rondean.co.uk/ – based in Birtley, County Durham
                                                As always, I have no connection to this company, I know people who have bought machinery from them.
