Acute (a cute?) tool sharpening system
Home Forums Workshop Tools and Tooling Acute (a cute?) tool sharpening system
Viewing 25 posts - 1 through 25 (of 62 total)
  • #210409
    John Haine
      @johnhaine32865
      Well, my kit for this arrived last Friday, delivered by Hermes in the form of a Vauxhall Astra rather than a winged chariot! My first impression – what a lot of bits! And more work than I expected, but none of it looks hard. Seeing it "in the flesh" I am even more impressed with the quality of the design, and there will be some interesting machining challenges, mainly in setting up (as always).
      I will try to keep a photo blog of progress and post here. So far I've assembled the base and table and made a start on the work arm, with no major issues.
      #17884
      John Haine
        @johnhaine32865
        #210415
          I look forward to following this, John
          … It does appear to be an excellent design.
          Vic
            @vic
            I look forward to seeing how you get on with this John. wink
            #210424
            RICHARD GREEN 2
              @richardgreen2
              Any chance of some pictures ?
              #210525
              John Haine
                @johnhaine32865
                Here is a picture of the assembled base.
                The table is supplied finished except for cutting out a gap to go around the wheel. The brackets and struts are ready made and drilled with pilot holes that need to be enlarged to clear the bolts. The kit includes 2 lengths of 1 inch ali to make the big spacers – these need to be faced to length and drilled 6mm through. One small problem, the drawings specify that one of the bolt holes in each bracket is slightly smaller than clearance, 5.8 or 5.8 mm, to lock the bolt from rotating. I found this impossible to achieve, so have added lock washers under the bolt heads so that they can be tightened with the handle alone.
                You also need to make the big "washers" that go between the adjustable handles and the struts/brackets – these are 5mm thick and have a radial groove ion one face to locate an O ring that provides a little bit of pressure to assist in smooth adjustment when the handles are slightly loosened. Two laser cut discs of MS are provided for these, but I thought it was easier just to turn and part each one from an MS bar. Once assembled the base is very rigid when locked, but easy to adjust when slightly loosened. Next job – the pantograph that carries the tool holder and clamps to the table. Watch this space…
                #210567
                John Haine
                  @johnhaine32865
                  This is the clamp block that goes on the top edge of the table. Supplied as a laser cut disc of 8mm steel with hole positions spot drilled. Centre hole is drilled out 5 mm and tapped M6x1. The other two holes are for the shoulder screws that form pivots for two of the parallel links. There is a 4mm step which has to be milled off the surface, parallel to the line of the pivots. I clamped the drilled part down to the mill table and set the shoulder screws square to the table edge using a big combination square – a bit tricky. The only way I could make my VMB reach the part was to use the longest cutter I had, which isn't over sharp so the finish is not wonderful. Now a problem I found was that the table material, nominally 4mm thick, is actually 3.85 so a 4 mm step is too large for the clamp to work. So I had to turn a shade off the top surface to bring the actual step down to 3.75 mm. Best to measure the table first and cut the step to suit. To turn the top and the sides I bolted the item to a short length of steel with a 6 mm hole drilled through, a bit like this…
                  This actually shows the sandwich of the clamp washer that forms the other part of the clamp and the pantograph joiner. Two ~41 mm laser cut discs are supplied with the latter having the hole positions spotted. I marked the centre positions thus:
                  popped the centres and drilled 6 mm after locating the centres using a point in the drill chuck. Then I turned the outside surface to clean up, and drilled and tapped the 4 holes M4. Next photo shows the clamp fixed on the table edge.
                  I need to shorten the threaded portion of the clamp bolt so it's flush with the top of the block when tight. Next, the pantograph links…
                  #210571
                    Thanks, John
                    Very useful information and photos
                    Please keep 'em coming.
                    John Haine
                      @johnhaine32865
                      Having drilled and tapped the link joiner the next job was to drill and ream the holes in the links.
                      Held in my little vice clamped on the VMB table, lined up using a point in the spot provided. Drilled 8 holes 5.9 mm then reamed out to 6 mm and deburred.
                      Next, the work head swivel. This goes at the other end of the pantograph and allows the work head to be turned to the required cutting angle and clamped. The large hole in the centre as supplied is about 36.5 dia and needs to be bored out to 38. The spottings for the screw holes are accurate in the cut blank but nothing else can be relied on. So I cautiously filed the straight edge next to the spottings smooth to the outline (which is laser marked on the edge, with about 1 mm machining allowance), and set it against a straight edge clamped square to the table. Then aligned the mill spindle to one of the spotted holes by holding a point in the chuck and adjusting the point so it entered the spotting accurately as judged by eye and feel. Then I clamped everything down, so we have the spottings aligned square to the table and the spindle axis aligned with one of the spottings. Then I moved the table Y by 15 mm which places the axis exactly halfway between the spottings; and X by 27 mm which places it in line with the centre of the big hole. Locked the slides, fitted the boring head, it needed 4 cuts at about 100 rpm to take the hole diameter to 38.02 mm – not bad.
                      Then I could drill and tap for the link pivot bolts and make a trial assembly, as shown here.
                      #210822
                      Vic
                        @vic
                        Thank you very much for the pictures so far John, very helpful. yes
                        #211168
                        John Haine
                          @johnhaine32865
                          Bit of a setback today. Have gone on to making the workhead which involves turning a very shallow shoulder on a couple of circular blanks laser cut from plate. As they are pre-cut the only practical way to hold them is to drill through the centre and hold on a stud into a mandrel held in the chuck. The material is very "sticky" and even taking very shallow cuts I've suffered 3 dig-ins that stalled the lathe, and b******d the tipped tool. So now started on one of those loops where I don't seem to have a spare tip that's sharp for the holder; try a different holder that I made that turns out to be bowed (never noticed before) so you can't easily get the tool to centre height, now I need to make a small mod to a tangential tool holder I made a while back but needs a dimension adjusting which means it's back to the mill….tired and frustrated, taking a break!
                          #211172
                          Vic
                            @vic
                            Don't get too downbeat John, we're all behind you. wink
                            #211173
                              Sounds like a job where a set of soft jaws would help.
                              John Haine
                                @johnhaine32865
                                You're right Neil! Another project…
                                #211207
                                Danny M2Z
                                  @dannym2z
                                  My last set of soft jaws (to hold a Cox engine backpate) went like this.
                                  Slit a piece of round aluminium stock axially with 3 slits (with one slit almost all the way to the centre).
                                  Pack the long slit with a few layers of aluminium drink can (according to width of slit), leave the ends projecting from the front face. Mount in chuck, do not remove it from now on but mark #1 jaw anyway as they are re-usable.
                                  Drill and bore the hole to suit the work then slightly loosen the jaws and pick out the packing without disturbing the alignment.
                                  Place your object in the new soft jaws and tighten the chuck. It will be concentric.
                                  About 20 Minutes work.
                                  * Danny M *
                                  #211214
                                  John Haine
                                    @johnhaine32865
                                    Thanks Danny, good suggestion.
                                    #211481
                                    John Haine
                                      @johnhaine32865
                                      OK, well I have turned both bits now, holding them as before but with different tools. I still find the material very "sticky" and suffered several dig-in/jams, but no matter, job done. I didn't take any photos of the operation I'm afraid, they would not have been very edifying! There aare now some easier operations to be done, which I will pick up tomorrow and hopefully post some photos.
                                      A bit of feedback to Eccentric: I've done quite a lot of turning steel of around this diameter (50mm) without problems like this, the plate material seems to be very "sticky" and prone to digging in. It might be easier if these two pieces at least could be supplied as blanks parted off from a bit of 2" FC bar perhaps?
                                      #211484
                                        Hi John,
                                        Not sure if you sent that feedback to Gary, but I'm sure he would be glad to receive it.
                                        John Haine
                                          @johnhaine32865
                                          A bit more progress. Have now progressed to the "ways" that bolt on top of the work head base. These are segments of circles, laser cut from plate, with hole positions spotted accurately but a general machining allowance round the edge of about half a millimetre. I started off confidently drilling the mounting holes but soon realised (should have thought before) that actually it is critical to machine all round the edge to get these accurate and there is no obvious datum other than the holes. After a lot of though in the small hours of this morning I've decided this is a job for my cnc mill, but will need a mounting fixture using the accurate (I hope!) drilled holes as a datum. That will be a job for Saturday when I can also take some photos to post. Watch this space!
                                          #212166
                                          BW
                                            @bw
                                            Posted by Danny M2Z on 09/11/2015 06:47:00:
                                            * Danny M *
                                            Hello,
                                            I don't understand this description – any pictures / web pages / previous threads that might help me please ?
                                            Bill
                                            #212438
                                            John Haine
                                              @johnhaine32865
                                              OK, so now the ways are machined all round. I made a little fixture (or is it a jig?) to hold them on my Novamill – basically a small square of 16 mm ali squared up so I could locate a corner datum, with a couple of holes coordinate drilled/tapped M4 to clamp down the blanks, drilled to exactly the required spacing (20mm) and at known positions relative to the corner datum.
                                              Way milling
                                              Here the adjustable way is bolted down using csk screws to pull the blank into alignment, in the process of profiling round the blank. The block is clamped down with a single M8 flange nut and braced against the mill fence which is at right angles to the table. 6mm end mill, 1000 rpm, 50mm/minute feed. This was the second part being milled, you can see that the cutter went 0.1 mm into the fixture first time round (deliberately) to clear all the periphery. I generated the toolpath by working out the exact dimensions and using G-Simple which is a free CAM package, highly recommended. Here is s picture grabbed from the screen of the simulated toolpath:
                                              toolpath
                                              And this is what the end product looks like with the ways bolted down and the work holder in the slot as a trial assembly.
                                              Trial assy.
                                              I also asked Gary at Eccentric about this and he recommended a much simpler method which I would have used if I'd thought of it! Here is what he said (he is quite happy for me to copy it here).
                                              "I found the simplest way to machine that edge was to drill both holes in the way then use a pair of dowel pins or two small pieces of rod in the holes and grip it in the milling vice. It doesn’t matter too much about the diameter of the pins so long as they are straight, accurate and are the same diameter. Put the pins through the holes and have them sitting on the top of the vise jaws supporting the way between them, this will ensure that any cut taken will be parallel to the holes. Make sure the top of the vise jaws are parallel with the table before taking a cut of course."
                                              Simples!
                                              Edited By John Haine on 15/11/2015 14:50:07
                                              #212622
                                              John Haine
                                                @johnhaine32865
                                                The other machining operation on the adjustable way was to add a little rebate for the adjustable tool slide. To do this I used Gary's methid to set up the part on my VMB – here's a staged photo after the job was done and the burr removed. Easy to set up and worked perfectly.
                                                The little vice I'm using here and in a couple of other photos is one I fettled from an item I bould from Chronos a few years back. I never used it much but it was a nice size for the Novamill so I thought I'd check it over. Hardly a right angle to be seen! I had to re-machine almost everything, and make a new moving jaw since the original was glass hard, but it's now very useful on the Novamill and also I seem to be using it more and more on the VMB since it's very easy to fit and align with a square to the table edge, though I use strap clamps rather than bolts on the big mill. Just in case of jaw lift, I position them on the moving jaw after clamping the work.
                                                #213650
                                                John Haine
                                                  @johnhaine32865
                                                  Quite a lot of progress but not so many photos I'm afraid.
                                                  This shows the nearly complete workhead with the tool block mounted on the little feed adjusting plate that sits in the slot on the workhead. Actually since taking this the plate has been completed with the feedscrew. This plate turns out to be quite tricky as the left edge (bottom edge in the photo above) fits underneath the rebate in the adjustable way whilst there is a slot that fits over a stop pin on the workhead.
                                                  This is the underside of the plate. The problem is getting the plate to clip in place as if you make everything to dimensions the whole thing can be assembled with the plate in place but it won't click out if you don't want to use the fence but just grind using the pantograph (e.g. for lathe tools) (you really need to watch the video to see how this works. My solution (after consulting with Gary) is to mill a chamfer along the botton right side of the slide and also along the bottom left edge of the slot – these are invisible from above when the plate is the right way up and don't affect the registration of the plate in the slot, but does supply some clearance when you lift the right hand side of the plate up to remove it.
                                                  Note also the short slot in the top of the block in the first photo – in the drawings just a blind hole is specified but I elongated this sidways as my stop pin was slightly out of position. There is a corresponding slot in the bottom face. The top face has a 5 degree wedge milled off, the secondary clearance on a cutter is set by inverting the block increasing the clearance by the same angle.
                                                  This shows the block in the vice set to 5 degrees off horizontal using a digital angle gauge for milling.
                                                  Another problem with the slide plate is that it is a little short of datum points to set it up for milling though it is square and patallel as supplied but needs a total of ~1mm machining off the long edges. However there is a slot accurately cut so I used this to measure to the edges to determine exactly how much needed to be taken off each, like this…
                                                  I've just about finished the workhead now except for some final fettling and making the tool holders, so have moved on to the the fence assembly.
                                                  #213953
                                                  John Haine
                                                    @johnhaine32865
                                                    Some progress with the fence.
                                                    This shows the fence parts so far, the stop block, the fence itself (which is supplied cut out and slotted, just needs one hole drilling), the tee nut and the locking screw/lever.
                                                    The assembled fence. The drawings show the block with chamfers on the edges, but actually I think it looks better all square. (Well, that's my excuse!)
                                                    No pictures, but the tee not was a simple turning & milling job from a bit of 12mm bar (supplied).  I popped in my dividing head (with Ward controller) and machined the flats to fit the wider part of the slot, then turned and parted off the final piece on th lathe.
                                                    The block is supplied as a lump a bit over 16mm long sliced from a 20mm sq. bar. The ends need facing to thickness (15 mm) then there are tenons to be milled in the base to slide in the slot and 3 screw holes, one for the clamp screw, one for the adjuster, and one for a pad screw that applies some friction through a nylon pad to the adjuster. As shown the block has been faced, drilled centrally for the clamp screw, and had the tenons milled.
                                                    For little jobs like this where neither end is square it's often convenient to clamp it in a 4-jaw on the mill table. This is an old, hardly used but much abused Burnerd chuck I picked up for very little from a market stall. I finally got round to cleaning it up and making a key for it for this job. The advantage of a 4-J for this is that it acts as a vice which constrains the workpiece around two axes so the other axis has to be vertical. Here it's shown drilling the clamp screw hole but I used a similar setup to face the ends.
                                                    I made the tenon on one end using the Novamill. Clamped the block to the table, used G-simple to generate code for a "rectangular bulge", and set it off. Note the use of a Mitee-Bite clamp, I've never had one of these slip when doing a milling job. They came with the machine, an ex-school unit I scored on eBay, though I had to make my own drive system.
                                                    Next, need to drill the remaining holes in the block, and make the clamps that fit the fence to the table. Then the basic unit is done and I can get on to the toolholders!
                                                    Edited By John Haine on 24/11/2015 15:16:30
                                                    #214455
                                                    IDP
                                                      @idp
                                                      Good morning chaps,
                                                      Looks as thought you are making a very nice job of this piece of kit.
                                                      I'd asked santa for the Eccentric Engineering book, thinking I'd like to have a bash at making one however santa's helper has been having trouble contacting Eccentric Engineering with no reply to telephone and neither from email. Does anyone have / can confirm contact details for this company.
                                                      IDP
