2″ Tee Bolt
2″ Tee Bolt
Home › Forums › Workshop Tools and Tooling › 2″ Tee Bolt
Viewing 3 posts - 1 through 3 (of 3 total)
  • #48192
    Anthony Spencer 1
      @anthonyspencer1
      Hi
      I am trying to locate a 2″ Tee Bolt for a Myford Swivelling Vertical Slide.
      I tried Myford but they only stock parts for the later 2 bolt fixing model.
      This is the centre bolt to secure the slide to the carriage.
      As my lathe is now stripped for overhaul I was hoping to buy one rather than have to wait and machine one up.
      Edited By Anthony Spencer 1 on 03/02/2010 12:40:02
      #16528
      Anthony Spencer 1
        @anthonyspencer1
        #48199
        Jim Whetren
          @jimwhetren72358
          Hello Anthony,
          I had a Myford  Swivelling  Slide which I used on a  Drummond lathe at the time.
          I found that when using it, the slide had a tendancy to move, so I replaced the single fixing with two bolts. It seems that Myford have had the same idea.
          My bolt had a seperate T nut screwed on the end, which I believe is slightly larger than a Myford one?
          In our tradition of ‘never throw anything away’ I still have the original T bolt which I think is about 1/2″ in diameter.
          Jim
