Deburing holes
Deburing holes
Home Forums Workshop Techniques Deburing holes
Viewing 25 posts - 1 through 25 (of 40 total)
  • #16045
    Vic
      @vic
      #376441
      Vic
        @vic
        I often seem to need to drill holes or drill and tap along a round bar or thick tube, what’s the best way of deburing the hole to get the best appearance? Using a standard countersink obviously removes more material on the “high” sides of the hole and sometimes wanders off for some reason leaving it looking even worse. Any suggestions? A countersink with a pilot would perhaps help get a neater result if such a thing existed. I’m using M6 most recently. TIA.
        #376444
          Countersinks with pilots certainly exist … 'though the ones I have are smaller than M6
          That would address one of your two stated problems; but the other is 'interesting'
          Vic
            @vic
            Having though about this a bit more I think I’ll try using a centre drill at much lower speed and see how that works. I’ve got into the habit of using spotting drills to start the hole then using a standard drill but a centre drill may be better. Still interested in others thoughts though. The last job was on a quite sticky bronze type of material and didn’t go well.
            #376453
            Chris Evans 6
              @chrisevans6
              Centre drills with a 118 degree profile are available and the shallower profile may help. Work with a three square (triangle) scraper by hand is slow but can give a good result.
              #376456
              Tony Pratt 1
                @tonypratt1
                Spot drill, drill, countersink & tap. having an uneven chamfer was never a problem in my machining days. Better on a mill if you have one to keep location constant.
                Tony
                #376459
                Vic
                  @vic
                  Chris, I should have thought of that, I have a small three square scraper.
                  #376461
                  Brian Sweeting 2
                    @briansweeting2
                    Use a round file across the hole.
                    #376464
                      I use a deburring tool.
                      Helps to have the right tip for the material and to go gently.
                      #376467
                      Ian S C
                        @iansc
                        If you do use a drill or counter sink, it's often best to just hold the drill in your hand and do it that way, just a turn or two is enough. Ian S C
                        #376472
                        Alistair Robertson 1
                          @alistairrobertson1
                          Back in my machining days we used a 90 degree countersink in a cordless drill to beburr holes for tapping and appearance. Our inspector would not accept any unchamfered holes and woe betide any draughtsman or designer who produced any design without the sharp edge removed! He was not averse to telling the boss that it was not acceptable but he was such a sharp guy that his position was secure. He could spot when there was an error in any project and must have saved the company a fortune over the years.
                          Alistair.
                          #376477
                          ega
                            @ega
                            I had occasion to cut the tip off a step drill and afterwards it occurred to me that, mounted in a suitable handle, it would make an effective countersink/deburring tool:
                            It works best, of course, when the preceding step is a good fit in the hole being deburred.
                            On the tricky question of deburring holes in tubes, I suppose a CNC machine could do the job; I just make do with a small half round scraper.
                            #376482
                            MW
                              @mw27036
                              Posted by ega on 18/10/2018 14:06:29:
                              You can get tube/pipe deburring tools designed to be used with a power tool such as an electric drill. I used to use these prior to loading bar into a cnc lathe bar feeder.
                              They seemed to work quite well so long as you kept your arm steady whilst you did it.
                              Michael W
                              #376485
                                Some interesting responses … most of which would suggest that I started with the wrong assumption: I had assumed [always dangerous] that Vic was drilling for M6 across the the diameter of bar of [say] 100mm or less diameter.
                                ega
                                  @ega
                                  Michael Gilligan:
                                  I had made the same assumption. Deburring the end of a tube cut square is, of course, easy enough and there are specialised tools (eg for plumbers' copper pipe) for the job.
                                  Axminster have a fancy deburring tool for their PGS system on their website.
                                  Edited By ega on 18/10/2018 16:10:58
                                  #376488
                                  Martin Connelly
                                    @martinconnelly55370
                                    The OP refers to holes with high sides and this does imply cross drilling rather than in a faced off end. Noga deburring tools work well for holes like this.
                                    Martin C
                                    #376492
                                    Vic
                                      @vic
                                      Posted by Martin Connelly on 18/10/2018 16:17:57:
                                      Martin C
                                      Yes, you’re right Martin. smiley
                                      #376517
                                      Tim Chambers
                                        @timchambers76147
                                        When I was an apprentice at Westlands in the 70's (I did'nt finish the course so I'm not an engineer sad) standard practice for deburring holes was a couple of quick twists with a larger drill bit hand held. On the lathe we used a triangular scraper made from a file. The scraper end was used for internal edges and the file part was for the outside.
                                        #376531
                                          Posted by Vic on 18/10/2018 17:12:21:
                                          Martin C
                                          So, having ascertained that my assumption was correct …
                                          What diameter of bar [or tube] are you drilling, Vic ?
                                          Sam Stones
                                            @samstones42903
                                            The three-cornered scraper in my original set of three M&W scrapers tended to be a bit clumsy for small holes.
                                            My real standby, especially for deburring tiny holes, was to modify the tip of a three-cornered needle file; i.e grind off the teeth and bring each flat down to a shallow (pyramid) point. A breeze to sharpen too!
                                            Unlike the results from a standard 60 degree centre drill however, deburring threaded holes this way can leave a less-than-true (none symmetrical) result.
                                            Sam smile d
                                            #376614
                                            ega
                                              @ega
                                              The book advice for threaded holes is to countersink before threading; I admit I often forget and have to put up with the result.
                                              #379175
                                              Nick Hulme
                                                @nickhulme30114
                                                Thanks!
                                                I'm stealing that idea!
                                                #379214
                                                ega
                                                  @ega
                                                  Posted by Nick Hulme on 04/11/2018 18:59:34:
                                                  Thanks!
                                                  Feel free!
                                                  Mine uses a metric drill that rises by twos but a more versatile tool would be in steps of one millimetre. Again, if you didn't want to tie up the step drill permanently it could be held in a chuck handle.
                                                  #379333
                                                  I.M. OUTAHERE
                                                    @i-m-outahere
                                                    The noga platinum set i have has tips for de- burring just about anything and does it with ease so i will stick to that .
                                                    #379338
                                                      Posted by XD 351 on 05/11/2018 19:06:30:
                                                      Useful looking set … but how small a diameter hole can it deburr ?
                                                      It all looks a bit hefty to help much with Vic's original question.
                                                      https://www.linear-tools.com/tools/platinum-box.html
                                                      Edited By Michael Gilligan on 05/11/2018 19:52:49
