Superglue for holding workpieces
Home Forums Workshop Techniques Superglue for holding workpieces
Viewing 25 posts - 1 through 25 (of 33 total)
  • #16013
    David Murray 1
      @davidmurray1
      #354252
      David Murray 1
        @davidmurray1
        Out of interest has anyone tried this – looks like a very useful technique if it works – **LINK**
        #354256
        Vic
          @vic
          Not tried it myself but I think “Clickspring” on YouTube has?
          #354258
          John Haine
            @johnhaine32865
            Modern variant of wax chuck used in clockmaking. Or shellac. Works well, smelly to take the workpiece off.
            #354270
            I.M. OUTAHERE
              @i-m-outahere
              Works well just watch out for heat ! If you want to watch some more interesting ways to hold parts in the lathe or mill trythese channels :
              Joe piecynski – has quite a few interesting vidoes on holding thin parts etc .
              Suburban tool – look how he holds a curved flexible piece of plastic to mill it down .
              #354286
              Thor 🇳🇴
                @thor
                Hi David,
                I use glue to hold pieces together while machining, as long has the work doesn't get hot it works well. I then use a hot air gun to loosen the work.
                Thor
                #354287
                John Haine
                  @johnhaine32865
                  Does anyone know what that blue painter's tape is? Is it masking tape? If not is there anything equivalent available over here? I've use the superglue chuck idea for holding clock wheels to machine the bore for example, mounting the part direct to an aluminium "faceplate", not thought of using a tape in between. I found the video very interesting, I hadn't thought of trying it on the mill though have tried shellac with mixed success.
                  #354291
                  John Haine
                    @johnhaine32865
                    Answered my own question I think.
                    I.M. OUTAHERE
                      @i-m-outahere
                      Question is what is the difference between blue masking tape and the plain old cream coloured one ? I reckon it is the same just dyed blue so it stands out on the shelf at the shop ! And they can charge more for it !
                      #354305
                      john carruthers
                        @johncarruthers46255
                        Good carpet tape will take light cuts. I've used it for wood turning as well as metal, no porblems.
                        Superglue – again for light cuts but melts when hot. Back up with a centre where possible.
                        #354314
                        pgk pgk
                          @pgkpgk17461
                          Posted by XD 351 on 17/05/2018 08:13:19:
                          Depends which blue tape you refer to. For masking paintwork in the house i use 3M's 3434 which is a blue low tack tape – way better than 'ordinary' masking tape.. easer to reposition/remove and less damage to recently painted surfaces. (cheapest source I;ve found is from an autodetailers bought by the 6-rolls for about 2 squid each). That's a paper-like tape but 3M also do a plastic type masking tape that costs more but stretches better for curves.
                          pgk
                          #354318
                          John Haine
                            @johnhaine32865
                            The plastic one sounds better if you were doing cars and also looks more like the one in the video.
                            Can any of our US based friends cast any light on this please?
                            #354391
                            Nick Hulme
                              @nickhulme30114
                              I use activated cyanoacrylate to hold Titanium, D2 Tool steel, Gauge Plate and other sheet materials down to Aluminium tooling plates for profile cutting, it's a very useful technique. I use carpet tape for acrylic and Carbon Fibre sheets.
                              #354394
                                MrsG. expressed an interest in these blue masking tapes, for needlework projects.
                                Our investigations led us to believe that the 'Kip' range is considered pretty much definitive.
                                Available here: **LINK**
                                http://www.decoratingdirect.co.uk/shop/product/search?searchword=kip&page=1
                                … Various advertisers may disagree, of course.
                                  I don't know, but it is different – it works as an adhesion promoter for 3D printing but ordinary masking tape doesn't.
                                  Ian P
                                    @ianp
                                    As I understand it, there is more than one type of masking tape that is coloured blue, so describing something as 'blue masking tape' is not helping. Granted there are not many blue masking tapes compared with a multitude of 'black insulation tape' types but two is enough to lead to confusion.
                                    Low tack masking tape can be any colour although I used to think that was what the blue signified.
                                    How does the adhesion promoter work? is it applied and then removed to clean the substrates?
                                    Ian P
                                    #354484
                                    Jon
                                      @jon
                                      Any old super glue works direct to part and backing. Can only take light cuts like the video in steels, aluminiums far easier.
                                      Used to take 3/8" thick steels down to a profiled 120 thou holes and lugs etc, rarely came loose with depth of cuts greater than video.
                                      #354487
                                      Alan Wood 4
                                        @alanwood4
                                        3M #2060 masking tape recommended on NYC CNC member forum. This is 'builder standard' tape and resists coolant much better. Available on Amazon in 'Green' version (20601). Loctite 4851 glue.
                                        #354500
                                        John Haine
                                          @johnhaine32865
                                          Neil, please could you specify what sort of tape you use, and if possible a source?
                                          #354595
                                          I.M. OUTAHERE
                                            @i-m-outahere
                                            Posted by Neil Wyatt on 17/05/2018 21:19:17:
                                            I went straight to a buildtak surface and never looked back ! Just about finished heat enclosure for the bed so i can print abs better , uses oven bags to shroud the bed and you can find it on youtube under heat enclosre for 3d printer .back to the op ,
                                            I had a look at my local hardware store and there seems to be thre distinct types of masking tape , the old cream coulured stuff and two types of low tac tape one blue and one green , i think the green stuff has a thinner edge to give a crisper edge on the pint but as i detest painting i never really noticed this ! The old cream stuff may have a coating on it to stop paint or solvent soaking into it and affecting the glue so maybe with the newer types of adhesives the blue and green tapes may not have this coating and therefore have a more porus surface ? One thing i do know is the new stuff doesn't lift at the edges when using enamel paints which was a real hassle with the old stuff .
                                            #354608
                                            clogs
                                              @clogs
                                              clogsif it's not to late to answer the masking tape question………
                                              the original plastic type masking tape was originally called "FINE LINE"……what ever the colour…..like it says, u get a clean fine line when over painting another colour…..pretty sure it was 3M that started it many many years ago… normal masking tape gives a rough edge……
                                              u should also know that masking tape has a time limit….not to the shelf where it's stored but how long u can leave it on…….most of the rubbish no name tape u buy at B+Q is just 24hrs…..most decent tape are usually 36, 48hrs then depend's if it's been subject to paint…….and just to mess with it again there are tapes that are designed for use in heated situations……
                                              the normal cheapo tape I use is removed the same day it goes on……like around door handles……and if it ever gets wet and stay's on for day's……..!!!!!!!!!!! oh crap……….
                                              #354611
                                              pgk pgk
                                                @pgkpgk17461
                                                I was quite suprised at the variety of tapes. The fine line 3M stuff is a vinyl tape I've used for masking off rc heli canopies for spraying and can be bent around complex curves fairly well and adhere wider less flexible tapes over the top if necessary. Amongst the paper based tapes the options seem to include temperature tolerances, degree and duration of adhesion and assorted 'proofings' against solvents and cleaners. The auto detailing 3434 tape i use for house painting is thus both low tack, water and moderately solvent proof and gives an edge you can't fault for domestic gloss and wall paints. i did the kitchen recently.. a couple of hours masking around the plastic tile edging, windows & doors, electrical fittings etc saves all that tedious cutting in… just dosh around everything with a 2" brush and roller as ya goes to catch most of the brushwork while it's wet. It peels off well too.. whereas some of the beige cheap stuff tears when you remove. I think the 3434 was designed for protecting plastic and rubber car parts from polishes and abrasives rather than use as a paint masker for cars.
                                                #354623
                                                Eric Cox
                                                  @ericcox50497
                                                  Having watched the video, all the super glue does is bond two pieces of tape together. The adhesive strength of the tape is what holds the Aluminium.Surely a large piece of double sided tape will do the job without the need for super glue.
                                                  #354639
                                                  I.M. OUTAHERE
                                                    @i-m-outahere
                                                    Yep seen that too ! Double sided ( or double stick tape as the Americans tend to call it ) is very handy and especially useful when you need to turn the outside diameter of a sheetmetal disc to size , just stick it to the faceplate and trim it down to size with light cuts .
                                                    #354656
                                                    Ian S C
                                                      @iansc
                                                      In my wood turning days I would attach a wooden disc to a face plate, put some PVA glue on that, then a piece of paper(I used pages from an old phone book), then more glue, then the piece of wood I was going to make a bowl from. Next day it was ready to turn. When finished, a tap on a chisel at the joint and the paper split in two. Metal would need a different glue.
                                                      Ian S C
