Stainless Steel (update)
Home Forums Workshop Techniques Stainless Steel (update)
  • This topic has 3 replies, 3 voices, and was last updated 1 May 2011 at 09:56 by Clive Hartland.
  • #67766
    David Costello
      @davidcostello75947
      Problem sorted, remember my post about twisting SS for plough shares,heat up with gas lamp,twist slowly with molegrips,result perfect with no crease.
      The only downside is removing the colouring,but buffing should take care of that.
      Thanks for your help.
      Dave.
      #15520
      David Costello
        @davidcostello75947
        #67769
        Colin Jacobs 1
          @colinjacobs1
          I find with my stationary engine projects and 80 grit emery wheel does the job then polish with emery cloth.
          #67786
          Clive Hartland
            @clivehartland94829
            If you want a very good polished finish then use a fine emery and rub bees wax into the emery, use in the normal way and it gives an excellent finish almost grain free.
