Advice on milling machine purchase
  • #521047
    David Keil 1
      @davidkeil1
      Hi all
      At the moment I have a proxxon MF70 milling machine, which I have used with some small success to make clock wheels etc. However it has limitations so I am looking to upgrade.
      Unfortunately space is limited so the smaller mini/micro machines would be better.
      Preferably cnc controlled or the ability to upgrade.
      Any suggestions would be appreciated.
      #15323
      David Keil 1
        @davidkeil1
        #521048
        David Keil 1
          @davidkeil1
          I should have added that its use would only be for small projects like clocks etc.
          #521054
          John Haine
            @johnhaine32865
            If you definitely want CNC I would recommend getting a s/h Denford Novamill though they are hard to find and you may need to upgrade the electronics.
            #521245
            Henry Brown
              @henrybrown95529
              Have you seen this thread on here David? Link
              #521247
                For small mini/micro sized machines capable of CNC work or a manual mill that can be converted then the Sherline would be worth looking at, they do them as CNC or sell kits of parts to convert the manual ones. I've seen some very good work done on them
                #521276
                Stuart Munro 1
                  @stuartmunro1
                  I have a Sheline mill, non CNC but with DRO., Lovely little machine with plenty of punch. Only one issue and that is consumable parts and spares/upgrades. The 'T' slots are smaller than most machines found in the UK. You either need to make a plate to put on the table that you clamp pieces to, or order Sherline bits from the only real UK importer (MillHill supplies of Basildon) or import from the US.
                  Similarly the spindle is MT1 and as such limited ranges of fittings in the UK.
                  But plenty of parts made by Sheline of excellent quality
                  #521278
                  Stuart Munro 1
                    @stuartmunro1
                    ps. dpp-engineering on e-bay is a US exporter of Sheline. You can call them or email them and they will quickly list the part you want and ship via international shipping. The result is that ebay quotes the all in price to you, shipping taxes etc and handles the settlement of all of these.
                    Found dpp very helpful as indeed is Kevin at MillHill. Just check MillHill prices with ebay, sometimes ebay is a lot cheaper, sometime not!
