Bronze Eccentric Straps
Home › Forums › Locomotives › Bronze Eccentric Straps
  • #201945
    Malcolm Harvey
      @malcolmharvey97633
      Is there any reason why I shouldn't make eccentric straps out of bronze plate instead of gunmetal castings? I have a decent sized piece of bronze plate of appropriate thickness that will unlikely ever be used for anything else. Unfortunately I cannot be more specific as to what type of bronze it is other than to state the obvious that it is less copper coloured than gunmetal but more copper coloured than brass! Loco is Titfield Thunderbolt in 3.5" gauge.
      #1439
      Malcolm Harvey
        @malcolmharvey97633
        #201952
          I've done it in the past with bronze when making engines to my own design where castings are not available but mostly use a slice from a suitably sized bit of cast iron bar for eccentrics
          #201956
          Malcolm Harvey
            @malcolmharvey97633
            Just had another look at them. They are actually turned from a piece of bar. I have two pieces about 5" diameter.
            #201976
            julian atkins
              @julianatkins58923
              Bronze will be superior to gunmetal castings. Bulleid refered to eccentric straps as 'disc brakes'!
              cheers,
              julian
              #201978
              Malcolm Harvey
                @malcolmharvey97633
                I think O V S Bullieid himself was a bit eccentric!!
                #201980
                Bob Youldon
                  @bobyouldon45599
                  Ah, a Titbolt Thunderfield, a wonderful little locomotive.
                  A piece of bronze is always a better bet than a gunmetal casting which inevitably seem to stretch after a period of use, better still cast iron straps running on steel eccentrics. A good friend of mine always referred to eccentric straps as band brakes!
                  Bob Youldon
