ER40 collet nut seized
Home Forums Manual machine tools ER40 collet nut seized
  • #14223
    Tony Pratt 1
      @tonypratt1
      #538728
      Tony Pratt 1
        @tonypratt1
        This is bugging me! I set up an M10 screw in my ER40 lathe collet chuck using a 9-10mm collet & nipped it up using moderate force on the ball bearing collet nut. After turning the screw I released the collet nut and took out the part. Now the trouble starts, as I continued to turn the nut everything locked up and no amount of force CW or CCW would budge the nut, the collet itself was free.
        I had to resort to Mr Angle grinder to nearly sever the nut in half to undo it, in all my years using ER collets I have never lubricated the threads or had any problem such as this.
        My question is has anyone else come across this problem? I am at a loss as to why it just all locked up.
        #538731
        Dave Halford
          @davehalford22513
          Only on cars, undo two turns then lockup I always blamed a bit of thread breaking off and jamming.
          #538733
          Tony Pratt 1
            @tonypratt1
            Thanks Dave for that insight! Definitely felt like something had jammed or sort of 'cold welded' together?
            #538756
            noel shelley
              @noelshelley55608
              Sounds to me like picking up or cold welding. such a part should have a light lube oil to try and stop it. Some metal seems very prone to it if dry and under load. Noel.
              #538762
              Thor 🇳🇴
                @thor
                Hi Tony,
                First time I have heard about an ER collet nut that has locked up. I do apply a drop of oil to the threads and have never had any problems with the ER chucks I have.
                Thor
                #538800
                DC31k
                  @dc31k
                  Isn't it galling when that happens?
                  #538811
                  Neil Lickfold
                    @neillickfold44316
                    They can do this if the inner thread is not cleaned out before putting the next collet or cutter in the chuck. Even just changing cutters in the same collet size, you really should should take the whole nut off and clean it all out and check that the body thread is all clean too.
                    #538820
                    John Baron
                      @johnbaron31275
                      Posted by Neil Lickfold on 09/04/2021 11:00:13:
                      +1
                      #538827
                      Tony Pratt 1
                        @tonypratt1
                        Posted by John Baron on 09/04/2021 11:17:48:
                        +1
                        Yes totally agree but the bloody thing had only been used maybe 2 or 3 times & looks damm clean to me. As DC31k says the term is 'galling' Thanks to all with your suggestions.
                        Tony
                        #538860
                        old mart
                          @oldmart
                          I have never had any trouble, but I think the threads are very slightly oily.
                          #538869
                          Dave Halford
                            @davehalford22513
                            Personally I don't believe that oil will stop a thread jamming or galling when not under load. Sometimes you can undo a bolt enough to spin the washer under the head then continuing to removing the bolt begins to include removing the thread as well.
                            The trouble is the process is so destructive you can't tell what caused it.
                            #538875
                            John Baron
                              @johnbaron31275
                              Hi Tony, Guys,
                              It only takes a sliver of metal to jam up a thread ! It can get down the slots in the side of the collet and into the threads.
