Boxford Model C leadscrew half-nuts
Home Forums Manual machine tools Boxford Model C leadscrew half-nuts
Viewing 25 posts - 1 through 25 (of 58 total)
  • #14214
    AJAX
      @ajax
      #537737
      AJAX
        @ajax
        I'm slowly ticking off a long list of jobs repairing an old Boxford Model C. This lathe has a 3/4 x 8 TPI acme thread leadscrew in reasonable condition. By contrast, the half nuts are worn unevenly, with a very noticeable sawtooth effect and they fail to hold effectively when feeding towards the headstock. The half nuts have a tendency to skip / jump when under the lightest of loads. Everything is done up snug and there is no obvious way to adjust or shim the half nuts any tighter.
        half
        My conclusion is the half nuts need to be repaired or replaced. Maybe the best solution would be to bore the thread out of the half nuts, replace with a sleeve nut, fix with epoxy and then split into two halves. I would need to fabricate a suitable jig. I have access to a suitable mill at work but tooling is limited. A ready-made sleeve nut might reduce the work, otherwise I'd have to make one myself including the internal thread. I haven't found any UK based suppliers online, only US based.
        The alternative solution might be to build up the thread (how?) and then tap the existing / repaired thread. I don't have a suitable tap and I'm not convinced it would be easy to tap the two split halves, held slightly apart, even if held in a jig.
        I suppose it's possible to make an entirely new half nut mechanism, maybe using a plastic insert melted onto the leadscrew thread, but I haven't given this option much thought.
        What would you do? Thank you.
        #537744
        troy Guyette
          @troyguyette14482
          make new half nuts or find similar half nuts from other part manufacturers.
          #537800
            The tricky part is the way they are on an arm as a casting and there is not much meat in the bit surrounding the threaded part. Not sure how easy it will be to find a nut in the UK. Then make sure your silver soldering is up to scratch to attach the embryo nut as the residual wall once threaded won't be able to add much support leaving only the back wall of the thead to grip.
            Given the number of SBs and Boxfords out there wearing out I wonder if anyone has tried a temporary 3D print nut and arm to enable the lathe to do it's own threading of the replacement.
            #537805
            mgnbuk
              @mgnbuk
              The original part was made from a single casting that was split after being drilled & tapped for the leadscrew – would it not be easier to make a complete replacement along similar lines than try to add a threaded insert ?
              Nigel B
              #537807
              noel shelley
                @noelshelley55608
                What material are the half nuts ? White metal ? It may be possible to cast new ones round the leadscrew, then unscrew and split. Just a thought ! Noel.
                #537814
                mgnbuk
                  @mgnbuk
                  Cast iron IIRC
                  Nigel B.
                  #537817
                    I would consider soldering them together, possibly with a shim between (if appropriate), and simply re-tapping  the threads. It might only be temporary fix – perhaps only lasting another 30 years or more?
                    Edited By not done it yet on 03/04/2021 13:03:05
                    #537828
                      NDIY – that's a really interesting suggestion.
                      #537833
                      mgnbuk
                        @mgnbuk
                        Interesting, but probably not practical. Unlike a Myford, which moves the half nuts vertically to engage & disengage the screw, a Boxford/ Southbend arrangement pivots the two halves :
                        So the "shim" to allow re-tapping would not be parallel & the engagement mechanism may not have sufficient travel to engage the screw after the modification.
                        Nigel B.
                        #537837
                          You could use the same method to repair as is common on Drummond M-type halfnuts. There have been a number of threads on here and at least one article in MEW in recent years on it.
                          Basically a "bobbin" is turned up out of brass with the internal thread to match the leadscrew. The OD is parallel with the small flange on each end for location.
                          The old thread is machined out of the halfnut pivoting lever by clamping it to the cross slide of the lathe and boring it with a between centres boring bar.
                          In the case of the Drummond, the bobbin is cut in half and soft soldered into the machined halfnut lever. With a pair like the Boxford, some care would need to be taken to get the two halves exactly aligned. Maybe as suggested solder it all together first then cut the bobbin in half.
                          #537848
                          AJAX
                            @ajax
                            Posted by troy Guyette on 03/04/2021 02:36:58:
                            If I could buy similar half nuts at a reasonable price I would consider doing so. But as has been mentioned since you posted your suggestion, the design of this part may not make this practical.
                            #537850
                            AJAX
                              @ajax
                              Posted by Bazyle on 03/04/2021 11:37:16:
                              I agree – there is no much material to bore out if I plan to make a threaded insert.
                              I hadn't even considered 3D printing a nut/arm. I have my doubts it would be viable but I do have access to a printer.
                              #537852
                              AJAX
                                @ajax
                                Posted by mgnbuk on 03/04/2021 12:00:20:
                                Nigel B
                                I'm not sure.
                                If I could make a jig to hold the two arms/nuts at the correct distance and was able to bore out the thread plus enough to install an insert, that might be easier to making a complete replacement. Maybe.
                                As it stands, the half nuts don't work so there's not much to lose in trying to improve them.
                                #537853
                                AJAX
                                  @ajax
                                  Posted by not done it yet on 03/04/2021 13:01:48:
                                  Do you mean soldering the two halves together? They need to be kept at a fixed distance apart and running a tap (if I had one) between the two would fail due to a lack of material. On the other hand, maybe the threads could be built up using solder? I have no recent experience of silver soldering (probably last tried it about 35 years ago). I frequently weld with a stick welder but can't see that helping much in this situation.
                                  #537855
                                  William Chitham
                                    @williamchitham75949
                                    Here's a pretty good video of a guy doing a brass sleeve repair on similar sized half nuts for a Craftsman lathe.
                                    Youtube
                                    William.
                                    #537856
                                    AJAX
                                      @ajax
                                      Posted by mgnbuk on 03/04/2021 14:11:32:
                                      Nigel B.
                                      I watched a video late last night – sorry, I don't have the link to hand – in which a Boxford owner managed to bodge a repair by adding a blob of weld to one of the engagement pins thus forcing the half nuts more tightly together. Seemed to work but was not pretty!
                                      #537857
                                      AJAX
                                        @ajax
                                        Posted by William Chitham on 03/04/2021 15:58:10:
                                        Youtube
                                        William.
                                        William,
                                        I watched that video too – and was about to comment on it after responding to everyone's replies. Yes, it's a good video and is making me feel more confident about this as a solution. Didn't he use epoxy to fix the sleeve?
                                        #537858
                                          Have you checked that the two half nuts are allowed to engage fully? If not, the wear rate would be increased.
                                          If movement is restricted the internal threads will not engage the Leadscrew sufficiently.
                                          So is there any means of adjustment, or facility to increase engagement? Could the heel on each of the two halves be fouling before full engagement?
                                          #537859
                                          AJAX
                                            @ajax
                                            This US supplier stocks acme sleeve nuts with left and right hand threads. It would save some work. Shame they aren't in the UK.
                                            Acme Sleeve Nut, 3/4 – 8, LH, Bronze
                                            #537860
                                            AJAX
                                              @ajax
                                              Posted by Howard Lewis on 03/04/2021 16:04:24:
                                              Both sides appear to be engaging "fully" (in as much as their worn state allows) but the sawtooth effect of the wear allows them to rise and jump the next thread, if that makes any sense.
                                              #537862
                                              William Chitham
                                                Haven't got there yet, now you've spoiled the ending! Boxford nuts might be more awkward to set up for the boring operation because of the levers but I think the the overall process looks very convincing. It might be handy to have a stub of leadscrew to help centre the nuts for boring.
                                                W.
                                                #537863
                                                AJAX
                                                  @ajax
                                                  Howard,
                                                  I don't see any means of adjustment. In an earlier reply I mentioned seeing a YouTube video where someone bodged (I mean REALLY bodged) such an adjustment with a blob of weld on one of the locating pins.
                                                  #537865
                                                  AJAX
                                                    @ajax
                                                    Posted by William Chitham on 03/04/2021 16:08:34:
                                                    W.
                                                    Each nut/arm has two removable pins that could aid with work holding in a jig. They also have a machined face. I think holding the work securely for boring is totally doable, just a bit time consuming for a one-off job. My greater concern is there is not much "meat" (as mentioned by another poster) to remove for a sleeve.
                                                    #537867
                                                      It would be too much to hope that the pins are eccentric to enable the arms to be adjusted?
                                                      If the two arms are going to be machined, (to remove the worn half nuts and then to bore / screwcut / tap the replacements ), they will probably need to be separated by a spacer, to simulate the fully engaged position.
                                                      If you want to Tap the thread, Tracy Tools may be able to supply a Tap, but it will be a high cost per thread, unless you want to make a business, or a habit of the operation.
                                                      Howardl
