Piston rings
Piston rings
Home › Forums › Locomotives › Piston rings
  • #180494
    andrew winks
      @andrewwinks64215
      Hi All
      An often discussed topic no doubt but I have installed PTFE rings on gunmetal piston running in a cast iron cylinder on my 5' gauge locomotive. It ran perfectly on air years ago and still does so today. Just wondering what the group thinks about this method of sealing, I keep thinking its not really "kosher" as it should have CI rings. But she runs however it may be a different story when saturated steam instead of compressed air.
      I did purchase some rings some time back with the intention of replacing the PTFE but I have read that gunmetal pistons don't appreciate CI rings.
      Comments appreciated.PTFE piston rings
      #1377
      andrew winks
        @andrewwinks64215
        #180505
        John Baguley
          @johnbaguley78655
          Hi Andrew,
          I started using PTFE rings years ago and never looked back but have only used them on gunmetal cylinders so far. One of the locos has very high superheat. I don't see any problem with using them in cast iron as you have.
          Edited By John Baguley on 20/02/2015 10:24:59
          #180532
          andrew winks
            @andrewwinks64215
            Thanks John, I've been mulling over it and I think I'll leave it as is and see how they last. I'm at the stage of construction where I've questioned a few plan designs, beefed up a few things here and there before the final home stretch of backhead fittings prior to first steaming. Cheers Andrew
