Inverter Rating
Inverter Rating
Home Forums Manual machine tools Inverter Rating
  • #396136
    Nick Clarke 3
      @nickclarke3
      Starting to look at inverters and wondered if there were any benefits (or indeed drawbacks) to using a higher rated inverter than strictly necessary – ie would a .75kW invertor be suitable for a .75kW (1Hp) motor or would a 1kW (or larger) be a better choice?
      Nick
      Edited By Nick Clarke 3 on 13/02/2019 19:08:45
      #13425
      Nick Clarke 3
        @nickclarke3
        #396143
        Thor 🇳🇴
          @thor
          Hi Nick,
          Have you read this thread?
          Thor
          #396144
          Mike Poole
            @mikepoole82104
            A 750W inverter should run a 750W motor or less with no problems. Often the actual motor current is one of the parameter settings so a smaller motor can be run at full performance and protected. Some more sophisticated inverters can run a self test to learn the motor that is connected and set relevant parameters. In general there is no point in overrating the inverter.
            #396159
            Martin Cargill
              @martincargill50290
              If the price difference between the two is small it may be worth going for the bigger inverter. You never know when you might want to upgrade the motor or the machine.
              Martin
              #396166
              Nick Clarke 3
                @nickclarke3
                Posted by Thor on 13/02/2019 19:28:14:
                Hi Nick,
                Thor
                I have now.
                Nick
