Manual lathe for large diameter turning
Home Forums Manual machine tools Manual lathe for large diameter turning
  • #322616
    Michael Checkley
      @michaelcheckley34085
      I'm investigating bringing some machining back in house (actually back to the UK) but we would need a gap bed lathe capable of turning a diameter of ~900mm. So far I have been searching for both new and used machines, as a DRO will be used I'm not worried about it being metric or imperial. Material being machined is aluminium and as the part is a ring only about 150mm travel is required. Depth of part is about 100mm.
      Not much luck so far and some distributors swapping between radius and diameter for the swing over gap isn't helping much.
      Any help or suggestions of brand to look for would be much appreciated.
      #13070
      Michael Checkley
        #322617
        Anonymous
          Vertical borer? Would be more compact, but may not be a fast enough cycle time.
          Edited By JasonB on 21/10/2017 13:09:32
          Edited By JasonB on 21/10/2017 13:10:17
          #322619
          Michael Checkley
            Hi Andrew,
            Thanks, ill have a look in to a vertical borer, I think that is how they are being machined at the moment. I have asked admin to delete this thread as the title is wrong. not sure how my name got in there.
            Edited By JasonB on 21/10/2017 13:10:40
            #322620
            Journeyman
              @journeyman
              This is called a vertical lathe may be the same as a borer, could be the tool for the job?
              Edited By JasonB on 21/10/2017 13:10:59
              #322624
              Michael Checkley
                Vertical borer looks interesting especially if we could fit a drilling spindle to the tool post as there are some holes to drill on a PCD
                Edited By JasonB on 21/10/2017 13:11:22
                #322627
                Mick B1
                  @mickb1
                  Back in the 70s I was turning big cable reel components for the Coal Board on a Binns & Berry with about a metre or more swing into a wide bed gap, but a max between centres of maybe 2M. I came to think well of the machine, but I can't remember any model no. I think it was already quite old back then.
                  Edited By Mick B1 on 21/10/2017 12:14:20
                  #322631
                  mark smith 20
                    @marksmith20
                    sound like you need a facing lathe of some kind such as:
                    or has been previously mentioned on the other thread:
                    http://www.ebay.co.uk/itm/Binns-and-Berry-short-bed-facing-lathe-9-750-VAT-/263232210839?hash=item3d49dcc797:g:KFwAAOSwep1Zy2~i
                    Edited By mark smith 20 on 21/10/2017 12:40:42
                    #322733
                    Michael Checkley
                      A Binns and Berry machine would certainly do the job, not sure we have the floor space for a machine that long though.
                      #322742
                      Clive Foster
                        @clivefoster55965
                        Vertical lathe was what was used at RARDE / DERA / DRA for such jobs. As I recall matters the guy who drove it didn't consider it unreasonably slow but never saw it in use myself.
                        Setting up on a facing lathe will be a PIA. Not a one man job. Probably crane involved too. Much easier to slide around on the horizontal faceplate of a vertical lathe.
                        Clive.
