Interesting looking mill on the bay
Home Forums Manual machine tools Interesting looking mill on the bay
  • #266150
    Alan Waddington 2
      @alanwaddington2
      Bit of a mash up, but looks like the basis for quite a versatile machine, cheap enough starting price too. Heavy old lump though.
      Never seen a mill configured like this with Z travel on the head rather than the table. Bit of a pain having to run round the back to adjust height I guess.
      Alan Waddington 2
        @alanwaddington2
        #266157
        Tony Pratt 1
          @tonypratt1
          Interesting yes, & only surface rustwink
          Tony
          #266213
          John Reese
            @johnreese12848
            It looks like a patternmaker's mill similar to Wadkin. It is almost large enough to require a building of its own. Forget trying to get it into the basement.
            #266237
              There's a wheel at front right to raise the knee, perhaps the rear one is to get the head in roughly the right spot?
              #266239
              Martin Connelly
                @martinconnelly55370
                Should be possible to fit a motor instead of the wheel at the back.
                Martin
                #266260
                Alan Waddington 2
                  @alanwaddington2
                  Posted by Neil Wyatt on 12/11/2016 18:49:07:
                  I think the front wheel is for the X axis Neil, I can't see how the knee could raise as the 2 front rails that the bed slides back and forth for Y movement look to be part of the base…..could be wrong mind ? certainly a unique piece of kit.
                  Edited By Alan Waddington 2 on 12/11/2016 21:02:48
                  #266269
                    I think you're right – looking at it sideways has addled my brain.
                    Alan Waddington 2
                      @alanwaddington2
                      It gets better, a quick google of Bohner and Kohle reveals that it's a universal mill, the table swivels. You can see the pin it rotates on in the centre of the table. If only I had a shed big enough !
                      Seems the wheel on the back isn't for raising the head, there's a motor on top of the column for that. The wheel rotates the column.
                      In fact it goes further than I realised, looks like the table rotates through 360 degrees….under power ! Now I'm really impressed……Who knew such things existed…Damn my tiny garage sad   Good example of a poor advert, don't think the seller has any idea of it's capabilities.
                      https://m.youtube.com/watch?v=C-CkEkYrjsc
                      Edited By Alan Waddington 2 on 12/11/2016 21:46:59
                      Edited By Alan Waddington 2 on 12/11/2016 21:52:02
