Boxford CUD change gears
Home › Forums › Manual machine tools › Boxford CUD change gears
  • #216225
    matt harrington 1
      @mattharrington1
      Hi All, I am after some gears for my CUD to enable screwcutting, I am particularly after the 127/135 gearwheel which allows imperial threading on a metric machine, but wouldn't mind getting hold of quite a few different ones, thanks
      #12593
      matt harrington 1
        @mattharrington1
        #216255
        MalcB
          @malcb52554
          Hi Mark, if you have not already done so, I would joint the Yahoo Boxford users Group.
          Not the easiest of sites to follow though. In there you will find charts showing all the specific gears you will need and their correct positioning. I have gone thru' the same exercise.
          A few I bought from Tony at lathes.co.uk.
          You can buy all from there but they are pricey. I think you will have to get the 127/135 from him as they come up very rarely on the Bay. You can get other odd ones off the Bay. Also try bedetools.com as they have quite a few. G and M tmachinery also have a few at film star prices.
          When you know exactly which you want, put an add in the wanted column on here.
          Malc
          #216258
          John Stevenson 1
            @johnstevenson1
            Try ebay but also put South Bend in your search, they are the same gears.
