The 16 has a 1 hp motor fitted to it…..or at least 750 w whether that's input power or otherwise …..
You will be hard pushed to find a drop in replacement of similar properties….
A single phase will be bigger, as will a 3 ph counterpart.
As an example,
I recently bought a 'big' lathe similar to the 290…. Has a 1.5 kW motor fitted…..
A 3 phase drop in isn't as simple…the new motor has a different footprint to the orig, so some metal butchery is involved, then it has a different shaft dia…. So a new pulley needs to be made…..l
Good luck resolving your problem
Edited By John Rudd on 29/07/2015 21:45:49
