Hi all, my depth readout started to behave erratically, replaced batteries, cleaned exposed section of bar and eventually disconnected and pulled it out to clean.
A flat copper spring fell out and I could not see where it came from, tried the gauge without it and for a while seemed to cure the problem.
However now still no good, reset it to zero but when the quill is moved the gauge jumps to all sorts of measurements.
I partially removed the front cover to see if that would enable me to remove the DRO but could not get it completely off.
Any ideas how to fix this?
Bill D.
