Boxford 8″ Shaper
Boxford 8″ Shaper
Home › Forums › Manual machine tools › Boxford 8″ Shaper
  • #12186
    Gray62
      @gray62
      Adjustment of drive gear
      #129076
      Gray62
        @gray62
        I recently acquired an 8" Boxford Mk2 shaper, in excellent condition although the meshing of the drive pinion with the crank gear is a little 'loose' for want of a better description.
        The manual states that this meshing can be adjusted by means of the gear shaft eccentric.
        The manual does not however, illustrate or describe how this adjustment is achieved.
        Do any owners of this machine know how this adjustment is carried out?
        cheers
        Graeme
        #129117
        John Baguley
          @johnbaguley78655
          Hi Graeme,
          I didn't realise the meshing was adjustable until you mentioned it! I didn't touch the bush when I rebuilt mine.
          Looking at the drawings I have, the bush for the drive axle is indeed eccentric. If you take the drive pulley off, the bush is fastened to the main casting with 3 clamps with 2BA bolts. If you loosen those bolts you will be able to rotate the bush and so adjust the mesh.
          Hope that helps,
          Edited By John Baguley on 09/09/2013 22:14:44
          #129155
          OuBallie
            @ouballie
            Thanks for that John.
            News to me!
            Must check my Boxford now.
            Geoff – One of the reasons I joined this forum – useful info!
            #133969
            Gray62
              @gray62
              Does anyone have any details/drawings etc of the optional vertical feed mechanism that was fitted to some of the later underdrive Boxford shapers?
              According to lathes.co.uk – When fitted with power vertical feed, the operating mechanism was cleverly designed to allow its pawl and ratchet assembly to be swung through 180 degrees to engage either movement.
              Mine looks to have been prepared for this in that it has the indexing gear fitted to the vertical movement drive shaft but some of the mechanism seems to be absent.
              Failing this I can feel an adventure into a CNC'd machine taking shape (Pun intended)
              CB
              #133974
              Saxalby
                @saxalby
                Hi CB,
                I can photograph the mechanism on my one if that will help.
                Regards Barry
                #133993
                Gray62
                  @gray62
                  Hi Barry,
                  Any info will be appreciated, photos are great,
                  many thanks
                  Graeme
                  #134004
                  Saxalby
                    @saxalby
                    Hi Graeme
                    Found this diagram of the horizontal power feed.
                    This shows the additions for vertical feed
                    Ratchet wheel and spur gear are keyed / pinned together but not to the horizontal feed shaft.
                    Hope this helps – Barry
                    #134044
                    Gray62
                      @gray62
                      Hi Barry,
                      Many thanks that info is great, where did this info come from? I have the manual but it doesn't give this type of info
                      regards
                      Graeme
                      #134051
                      Saxalby
                        @saxalby
                        Graeme,
                        Got the diagrams from the Boxford web site, under their spares listings.
                        Barry
