Harrison Universal mill
Home Forums Manual machine tools Harrison Universal mill
  • #127444
    Brian Jopling
      @brianjopling20760
      I have a Harrison universal mill and the cross lead nut is worn. Anybody know where spares might be available – or will I have to machine a tap to make a new onesad.
      The feed is a seperate motor driven gear box with change wheels – which is a a pain. Anyone converted this to a variable 3 ph speed drive who could give some advice?
      Jopo
      Brian Jopling
        @brianjopling20760
        Spare parts/feed conversion
        #127460
        john kennedy 1
          @johnkennedy1
          I have the same machine. I took the feed motor and gearbox off and put a new leadscrew an nut on. Bought from 'Marchantdice'. Of course you lose the power feed so I'm making a feed to fit on the end of the table by using a stepper motor and related gubbins. John
          #127462
          Brian Jopling
            @brianjopling20760
            Thanks for that John. My bed lead screw is in v. good condition and I would like to try the fitting of a speed control to the feed motor first. My plan would be to fit the fastest gear train and vary that.
            Would like to know how you get on with your mod – in case!
            I also intend to find a suitable dro kit but would dearly love to find a sensitive vertical head (if such a beast exists).
            Jopo
            #127477
            john kennedy 1
              @johnkennedy1
              Jopo .. Mine ran off a speed control but the backlash was so bad I had to do something about it. It is rather a bulk hanging under the table and feels a lot better now its off. Thanks to 'd'costa' who is a member on here, I've started to make my own power feed. Will put more photos in my albumn as work progresses. John
              #127482
              Brian Jopling
                @brianjopling20760
                John. Time for serious thought methinks.
                Jopo
